"Cleaning" the Charcoal canister?
Discussion in '60-Series Wagons' started by High Desert, Aug 1, 2006.
  1. High Desert
    High Desert
    1,227
    1
    Mar 21, 2005
    Central Oregon
    I have of late seen several post on "cleaning the charcoal canister". Several post have indicated that the canister could be a source of idle problems due to being clogged or etc. My search turned up more indications of the canister being a problem but not how to resolve the problem. It's just full of charcoal..isn't it?
    I didn't know it could get dirty, thought it just filtered fumes from the fuel line.
  2. loeky
    loeky
    616
    Mar 24, 2005
    san francisco
    from memory, you blow compressed air through it a certain PSI which i forget unfortunately. basically just dust it out under pressure. all that pertinent info is in the emissions manual - deffinitely worth the $15 to purchase.
  3. High Desert
    High Desert
    1,227
    1
    Mar 21, 2005
    Central Oregon
    Uh, yeah, emissions manual, maybe I could pull one of them off the shelf and look in there...damnit..and duh...didn't even think about that..
  4. brett76
    brett76
    1,264
    1
    Aug 17, 2005
    t town, wa
    when yuo find it wil you answer your question for us folks who are without said emissions manual?
  5. High Desert
    High Desert
    1,227
    1
    Mar 21, 2005
    Central Oregon
    Yep, less I go Stoopid again..
  6. 2mbb
    2mbb SILVER Star
    4,612
    54
    Sep 1, 2003
    WC, CA
  7. brett76
    brett76
    1,264
    1
    Aug 17, 2005
    t town, wa
  8. MJ_Oregon
    MJ_Oregon
    92
    Jun 6, 2005
    What does the charcoal cannister do? What would happen if someone bypased it that didn't have to worry about emissions?
  9. Southbound
    Southbound
    609
    12
    Mar 3, 2006
    CA
    As far as I know the only function of the cannister is to control evaporative emissions. It does, however, also serve as the main vent for the fuel tank. The charcoal traps hydrocarbons from the gasoline vapors so they are not released into the atmosphere. My cannister is clogged, which means the gas tank can't vent properly and I occassionally get gas spewing out of the gas cap. I recently took FJ40Jim's advice and switched the "fuel" and "purge" lines on the cannister, effectively bypassing it, and haven't had any venting problems since.
