cleaning female connectors - and EDIC issues
Hey all,
I was wondering if anyone has a good way to clean the female side of a 10 pin connector.
Here's the story: I just recently picked up the EDIC relay for my 1981 BJ42 from the PO. He told me it was blown/no good, but I wanted it anyway because I like to tinker with things. After doing some tests this afternoon (thanks Lostmarbles and others for posting up this process here on Mud), I realized that my relay is functioning properly - clicks at the appropriate times during the tests. So, I connect it, but nothing happens. After a little more reading, I test the EDIC motor and it seems to function just fine - spins when I jump the M terminal. Hmmm?
So, I start looking at the connector and see quite a bit of corrosion. I use some baking soda and water to clean up the corrosion, but now there's a gooey mess inside the female side. I used some sand paper and a small screwdriver to clean up the male side, but how do I clean out the female side? I've tried wire, but that just rubs the goo around. Sand paper just wads up and doesn't go in. I don't have a file small enough to fit inside there. So, any ideas?
I'd like to get the EDIC system working if I can. I should mention that I do not have the EDIC arm attached currently. I have a choke cable set up to kill the engine. But, with the relay attached, the EDIC motor does nothing no matter what position the key is in - no movement. That's why I'm guessing maybe the corrosion is causing too much resistance in the circuits.
You can see the corrosion inside.
And here's a video of the EDIC motor turning. Off topic, but how do you embed a youtube video?
YouTube - EDIC motor
So, any ideas?
Thanks!
Hey all,
So, any ideas?
Thanks!
