Christo can you post that RPM/gear ratio figures?
Discussion in '80-Series Tech' started by yomama, Apr 4, 2003.
  1. yomama
    yomama
    291
    Mar 27, 2003
    Christo,
    Hopefully you saved a copy of that?
    Someone here is running the 4.88's? Are you running 35's?
    I am thinking about going with 4.88's on a 33" tire.
    What is the max width tire that we can run on these stock rims? Currently running 285/75/r16. Would like 33/12.5/16 in the SSR flavor. Is anybody running these?
    Yomama
  2. sleeoffroad
    sleeoffroad Supporting Vendor
    6,056
    531
    Mar 27, 2003
    Re: Christo can you post that RPM/gear ratio figur
    Nope, that was not me. 4.88's with 33's would be a bit much in my opinion. Especially since you have the turbo to help you with the towing. I have had 37" SSR's on stock wheels but they were beadlocked :D
    33" SSR's on stock wheels will be fine.
  3. Photoman
    Photoman SILVER Star
    1,145
    Media:
    41
    47
    Mar 28, 2003
    Yo- Here is a link to one of many sites with these calculators. http://www.ring-pinion.com/c-rpm.html
    Also, here is a trans ratio table that Cruiserdan put up on sor and I shamelessly saved. Hope this helps.
    Bill
    Landcruiser trans ratios
    FJ80 A440F 1-90 to 7-92
    1st 2.950:1
    2nd 1.530:1
    3rd 1.000:1
    OD .717:1
    R 2.678:1
    fluid cap 16.4 US qts DEXII/III
    FZJ80 A442F 8-92 to 12-94
    1st 2.950:1
    2nd 1.530:1
    3rd 1.000:0
    OD .765:1
    R 2.678:1
    FZJ80 A343F 1-95 to 1-98
    1st 2.804:1
    2nd 1.531:1
    3rd 1.000:1
    OD .753:1
    R 2.393:1
    fluid cap 11.7 US qts DEXII/111
  4. Keep
    Keep
    251
    1
    Mar 27, 2003
    Chapel Hill, NC
    I remember this post. Its the one that clearly shows the superiority of the A442F. [​IMG]
  5. yomama
    yomama
    291
    Mar 27, 2003
    Keep.... :slap:
    Wow, just noticed the "fluids" part. 5 more quarts used on the older ones, that is interesting.
    Yomama
  6. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,605
    2,983
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    I also posted it here. It's on page 1.
    To add a bit.....Using the table and some math tells you what you want to know.
    EG: average 275/70/60 tire makes 667 revs per mile. 667 x 4.1 = 2735 driveshaft RPM = 60 mph. x .765 (in the case of a 442) = 2092 driveshaft rpm. at 60 mph in OD with stock tires and gears. I say driveshaft rpm because there is a torque converter in the equation. If it is un locked, your rpm will vary.
    EG2: average 315/75/16 tire makes 600 revs per mile. 600 x 4.56 = 2736 rpm, almost a dead match to 4.1/stock tire.
    ARE YOU BORED YET?......... :beer:
    (A bit slow at work today) :dunno:
  7. Hltoppr
    Hltoppr SILVER Star
    2,020
    Media:
    4
    3
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    :bow: :bow: Long live the A440! Except for the 2-3 shift weirdness, that part sucks... :-/
    -H-
  8. yomama
    yomama
    291
    Mar 27, 2003
    Were the stock Michelins 265 or 275? I thought they had been 265.
    Yomama
  9. cruiserdan
    20,605
    2,983
    Mar 27, 2003
    275/70/16........Lots of people put 265's on as first replacements because most of the tire shops did not have or know of the 275's.......If I am not mistaken, the only vehicle to spec this tire is the Landcruiser........... ::)
  10. T Y L E R
    T Y L E R
    2,598
    2
    Mar 27, 2003
    ............................................................................................................................................................................................................................................................................................whaa?
    Oh .. I'm sorry , I must have fallen asleep !
    Um , thanks CD !! Next time post that techie stuff closer to bedtime , will ya ??
    ::) :p :D
  11. cruiserdan
    20,605
    2,983
    Mar 27, 2003
    Good night.....sweet Prince...... :D
  12. landtank
    landtank SILVER Star
    18,425
    601
    Mar 27, 2003
    Groveland MA
    Yo, I might be the one your looking for. I'm running 4.88s and 315s which is a 35" tire. If you're thinking of going with 33"s don't expect a top speed much past 65 mph and wringing the piss out of it at that. A ratio of 4.56 with 33 would be more in line with what I'm running now. And at that ratio it would be slightly lower than stock by about 5%.
    Rick
  13. '74 UA FJ
    '74 UA FJ
    3,338
    62
    Aug 11, 2005
    Alabama
    Bump since it took me way to long searching on here to find a thread with transmission ratios in it.
  14. airlaird
    airlaird
    1,346
    3
    Jan 7, 2005
    Dallas, Texas
    Please remember 4:56's on 35's VS 4:88's on 35's is exactly a 100 RPM difference...believe me...I have had both set ups.
    airlaird
  15. AdventureBuddies
    AdventureBuddies
    689
    1
    Oct 28, 2007
    SoCal
    Very interesting - thanks for posting. I have 315s with 4.56 and my speedo is exactly accurate which makes sense since it nearly replicates the stock set up.
  16. Atoyot1031
    Atoyot1031
    2,122
    13
    Nov 16, 2006
    Aspen, CO
    This is my lazy two part question to someone who likes figuring out such things (Cruiserdan perhaps;)):
    So with 315s and 4.88s what percentage is the speedometer off by?
    Would not that percentage be the same percentage that the odometer is off by?
    Thanks,
    Nick
