chevy rear main seal
Discussion in '40- & 55-Series Tech' started by nuclearlemon, Feb 11, 2005.
  1. nuclearlemon
    nuclearlemon not an addict Moderator
    15,561
    Media:
    87
    389
    Jan 30, 2003
    meh-ico, colorado
    how hard is it to replace a chevy 2 piece rear main seal? any tips? i figure while i've got everything pulled apart to do the shift fork in the tcase, i may as well do the rear main that's been leaking worse and worse over the last two years.
  2. lone gunman
    lone gunman
    1,387
    2
    Aug 17, 2003
    granite falls WA.
    its not that hard, pull the pan and the rear main cap and you should be able to pull the old seal out aroud the crank. needle nose pliers may help, clean the area best you can and you should be able to slide the new seal around the crank. and stagger the end of the seals halfes so that they dont line up were the cap meets the block (it helps to prevent future leaks) slightly offset so one end of the seal stikcs out of the block and the same on the cap, add a dab of sealer to the ends and torque to spec, i think its like 75 ft lbs. of course its always easier if the cranks pulled but can still be done, hope this helps and didnt confuse you. good luck!!
  3. 1FE pig
    1FE pig
    222
    Dec 5, 2004
    Helena MT
    Pull the oil pump, the pump drive shaft will slide out to.Next take out the bolts holding the rear main.You gotta tap it with a deadblow to knock it loose.That side the seal just pops out,on the block you push out old one with the new one.Make shur the lip of the seal is faceing the right way.---it's the most important part---install the main ,torq it.line the shaft with distrib slot and oil pump slot run down bolt.
  4. nuclearlemon
    15,561
    Media:
    87
    389
    Jan 30, 2003
    meh-ico, colorado
    damn...what happened to the simple pull tranny, pull clutch/flywheel, pop out old seal, push in new seal, reinstall trans, clutch and flywheel?
  5. VTFJ40
    VTFJ40
    632
    Jun 16, 2004
    Northern Vermont
    86 and up sbc are like that.
