This is my first time replacing the ball joints on my 84 K10 Suburban and I am running into an issue with the upper ball joint adjusting sleeve. When I removed the knuckle from the axle the old adjusting sleeve was pretty much centered in the upper C.
Following the FSM, I torqued the lower ball joint to 30ftlb, then torqued the adjusting sleeve to 50lb. This is where the new adjusting sleeve is, mostly below the C. This doesn't seem right to me. Is this normal?
