Checking VSV for EGR easy way P0401
Discussion in '80-Series Tech' started by Alex Kogan, Mar 19, 2008.
  1. Alex Kogan
    Alex Kogan
    41
    2
    Jun 26, 2005
    Portland, OR
    Well I got bit with that bug too. Sorry if I missed something, although most common culprit has been long identified - VSV, most of ways to check its operation are rather tedious. Here is my easy way.
    Disconnect VSV connector from main engine harness. Check for continuity between two terminals with yellow wires on opposite side. You must have something like 30-35 oms. No continuity = bad VSV.
    [​IMG]
    Otherwise rig up something to connect those terminals to battery.
    [​IMG]
    Then disconnect a vac hose from EGR valve. If you can blow air through or suck it out of it when terminals are connected to battery = bad VSV. (when disconnected - air should be able to flow).
    [​IMG]
    Ones VSV is removed you might want to double check findings but I really fail to see why Toyota in shop manual recommends to remove intake plenum to just check VSV.
    If all checks out, look elsewhere.
    On the side note. I've seen a advice to clean passage through intake manifold. Well, clogged up passage could only conceivably cause code P0402 not P0401 since it would induce too much vacuum above membrane of EGR valve thus opening it too much. Role of VSV is to prevent vacuum built up unless ECU decides that now is a good time to close it.
    Just my $0.02
    BRob2756 and GW Nugget like this.
  2. bpenn1980
    bpenn1980
    916
    3
    Nov 15, 2007
    Los Angeles
    Awesome, this saves me a big pain in the arse. Like you said, the only testing methods I've read mean pretty much removing the VSV. If I'm going to be doing that I might as well get the starter rebuilt, PHH knocked off and replace the fuel filter :D
    I like your way and will be employing it on my rig this weekend. Gracias
    NLXTACY likes this.
  3. MoJ
    MoJ Moderator
    3,281
    50
    Oct 24, 2003
    nice write-up
  4. superhawk
    superhawk
    22
    Feb 16, 2008
    Milwaukee, WI
    quick question
    Man this was helpful. After I threw a code 71 (1994) I was frightened to see how many things could be wrong with the EGR system. I just did this test and registered about 29.7 ohms, so I am guessing that is close enough to the range. Anyway, my question is this: Is there anything of mechanical nature that could go wrong with the VSV, or is it safe to assume that along as there is enough continuity the VSV is OK.
  5. Bluetribal
    Bluetribal SILVER Star
    4,745
    64
    Mar 14, 2006
    Sandy Eggo
    I just threw this code last Friday before heading to Baja, truck did great in Baja for the weekend but now it's time to make that engine light stop looking at me. Thanks for this and hopefully I can test it out this weekend.
  6. Ted44
    Ted44 SILVER Star
    202
    Oct 14, 2005
    Waynesboro, VA, USA
    With one caveat.
    Some here, me included, have experienced a VSV for EGR that is intermittent in its function. Of course, this means it is bad in my book, but it may not always show up as bad when testing it.
    FWIW
  7. Imagery
    Imagery
    343
    1
    Aug 26, 2003
    Beaumont, Texas
    All I can say is Good Luck. I've been looking at my CEL, PO401 for a couple years now and I have tried to track it down myself with the mothods outlined in the FSM with no success. I have had two shops attempt to find and correct it, the first one replaced the EGR valve itself and the last one, just a couple weeks ago, replaced the VSV for $150 and neither one worked. The light stayed off each time they cleared it and came back on after metting the criteria of running at 52 mph for however long, three times and then it comes back on. I am not going to pay anyone else to try to find it so the next thing I plan on doing is removing the intake manifold and cleaning out all passages ect, then see if that works. I surely don't want to pay someone to do that because if it doesn't work, i'll have to keep bringing it back until they finally give up. It's kind of frustrating to not be able to resolve the issue but I don't feel like it is causing any problems to the engine performance and fuel mileage.
  8. bpenn1980
    bpenn1980
    916
    3
    Nov 15, 2007
    Los Angeles
    I'm Code 71 free! I found the plug (looks different on a '94) and went to pull it. Wouldnt you know it, the damn thing wasnt fully pushed on! I pulled it, blew it out and plugged it back in. 363 miles free of that damn CEL, and I averaged 16.6 mpg for over 200 miles!
    :beer:
  9. landtank
    landtank SILVER Star
    18,000
    335
    Mar 27, 2003
    Groveland MA
    I posted a while back about those two wires, however they are only reliable if the resistance is within spec. If the resistance is out of spec you still need to pull the VSV as there is another connector between those test points you show and the VSV itself.
  10. Alex Kogan
    Alex Kogan
    41
    2
    Jun 26, 2005
    Portland, OR
    Yes (second part of the post), you need to hook up those wires to battery and make sure that you can't blow air through VSV via hose connecting it to EGR valve. Having resistance means that coil in VSV is not shorted but it may still not be able to close internal valve preventing vacuum build up in EGR valve.
  11. MLX450
    MLX450
    610
    2
    Apr 10, 2005
    Silverdale, WA
    Did you replace the modulator?
  12. Alex Kogan
    Alex Kogan
    41
    2
    Jun 26, 2005
    Portland, OR
    Just an update.
    Kudos to CDan the parts man. New VSV is in, MIL is off, EGR emission readiness monitor passed.
  13. teeth geek
    teeth geek
    4
    1
    Apr 1, 2010
    Great Info on this thread
    Newbie here. Signed up to say thanks for the test information. I tested mine and got infinite resistance so off with the VSV using info from IH8MUD. After replacing the VSV, :steer:I drove it and scanned the OBD II and have only one readiness code left so I'm off to the biannual Smog Check tomorrow. Thanks again.
  14. johnnyllama
    johnnyllama
    117
    Oct 26, 2009
    Winter Park FL
  15. S.CarolinaFZJ80
    S.CarolinaFZJ80
    2,368
    76
    Oct 4, 2008
    Thanks. I will try this test as I constantly get the 0401 code, even after the PO replaced VSV, EGR & modulator 13,000 miles ago. I even removed the upper intake plenum, cleaned/reamed all holes/ports and replaced the tubing a few months ago and to no avail.
  16. powderpig
    powderpig SILVER Star
    1,007
    5
    Jul 12, 2005
    Boulder Foothills, CO
    If everything also check out, check the temp sensor. I have replace two of these in the last year. Everything check out, had me stumped for a little bit. Then remember the computer only know the gas is flowing or not if the temp sensor is working.
  17. Flank
    Flank American by Birth, Texan by the grace of God.
    1,943
    126
    Mar 20, 2008
    Flower Mound, TX
    Have you pulled your throttle body to see if the port from the EGR to TB is clogged? Mine was pretty bad.
  18. Round rock cruiser
    Round rock cruiser
    3
    Oct 29, 2011
    P0402 code ewww
    Hey guys I've been reading your thread about this code, here may be a silly question does it narrow it down any if I'm getting terrible gas mileage as to egr, vsv, etc. ?
    Any help very much appreciated.
    I have a 97 landcruiser
  19. Flank
    1,943
    126
    Mar 20, 2008
    Flower Mound, TX
    Not really. The EGR system is an emissions control system. That being said, some of us have realized better performance after servicing the EGR, mainly do to the fact we've also cleaned out our intake plenum, throttle body and changed out vacuum tubes. Many people actually just disable the EGR (illegal in most areas) and don't see any change in either mileage or performance.
  20. Pin_Head
    Pin_Head
    13,198
    915
    Feb 6, 2002
    OC, CA
    For that code, the first thing you would want to do is make sure the EGR valve is not stuck open. Check for a rough or low idle and see if the idle improves when you whack the valve with the handle of a screw driver. If not, then check the valve for function by pulling a vacuum on the EGR valve actuator. It should stall or idle rough with vacuum applied and idle smoothly when you release the vacuum
