Check Engine light come on after oil change never done it before. help
Discussion in '95-older Toyota Truck Tech' started by toyota884runner, Nov 24, 2005.
  1. toyota884runner
    toyota884runner
    21
    Nov 6, 2003
    Check Engine light come on after oil change never done it before. it came on right after i drove up a hill and stays on. the dipstick says it is fine oil wise. what could it be?? it's a 88 4 cylinder 22re 4runner. please reply
  2. pbgbottle
    pbgbottle Forum Lifer
    4,559
    Media:
    92
    236
    Feb 8, 2004
    Cloverdale B.C. Canada
    sometimes they come on after a certain amount of miles say, 80,000 100,000 130,000 ,just to get you in to the dealer, you can try disconecting the battery for a few minutes , if it is nothing serious it will reset the error code and light will be off , don't no much else about your year it is pre obd2 , ?? could be your o2 sensor went bad ?? who knows just giving you some suggestions .
  3. KLF
    KLF Frame waxer SILVER Star
    6,298
    518
    Apr 5, 2003
    Southern NH
    Toyota's don't do this. AFAIK, BMW is the only car that pulls this stupid stunt, but there may be others.
    Read this article:
    http://www.off-road.com/toyota/tech/codes/
    Grab a paperclip, jumper the diagnostic connector (yours is attached to the fuseblock right behind your battery), read the flashing code. Repair as appropriate.
  4. lunyou
    lunyou
    2,403
    Oct 24, 2005
    Cuba, MO
    When the light comes on do you notice a difference in the way it runs(accelerates/deccelerates)? If you do its probably the O2 censor. My 93 did this and i had it fixed.
    My previous 85 4runner's check engine light came on and stayed on til the day i wrecked it which was many miles. I would say look for obvious things and unless you want to go have it diagnosed just ignore it.
    lunyou
  5. bkg
    bkg
    657
    2
    Oct 1, 2004
    Stupid question, but are you sure you filled it w/ oil? The oil pressure light and check engine, I believe, will come on w/ low pressure.
  6. Bob_Garrett
    Bob_Garrett
    1,195
    2
    May 17, 2003
    Irving, TX
    Is the oil filler cap on and tight? Check all the electrical and vacuum hoses in the areas of the motor where you were working to make sure you didn't accidently knock something loose.
  7. Jukelemon
    Jukelemon
    2,395
    2
    Dec 29, 2003
    Louisville, KY
    Did you spill oil on a sensor-namely the temp coolant sensor? It is right there to the left of the cap.
  8. Red_Chili
    Red_Chili
    68
    Nov 16, 2005
    Littleton, CO
    Pull the code, reveals all secrets. My bet is on a coincidence, and it's either your TPS or your O2 sensor. Or both.
  9. KLF
    6,298
    518
    Apr 5, 2003
    Southern NH
    Nope. There are no codes in the ECU system for "No oil pressure".
    It often takes several repetitions of an error condition before the CEL comes on. If there was no oil in the engine, it would have siezed by now.
    If you can find a paperclip, you can pull the codes. It's really easy.
