chassis/frame dimensions fj40
Discussion in '40- & 55-Series Tech' started by juanix, May 12, 2003.
  1. juanix
    juanix
    17
    Apr 1, 2003
    i just pulled the body off the frame of my 40. i noticed that the frame was slightly bent up.does any one have the original dimensions of the frame or can anyone direct me to a site where i can find a layout/bluprint?i believe i saw a site before just cant remember where. :-/tnx
  2. Trevor
    Trevor
    883
    1
    Mar 11, 2002
  3. KY Longhunter
    KY Longhunter
    3,037
    Media:
    1
    178
    Aug 25, 2007
    Bowling Green, KY
    Looking for dimensions from mid tub bridge mounts to rear crossmember body mounts. Can anyone get me these?
    Does anyone know where this diagram came from. The bottom is cut off, specifically the rear crossmember which is where Im needing help!
    Fossil likes this.
  4. shelfboy1
    shelfboy1
    3,796
    180
    May 7, 2006
    erie pa
    fsm has all the dimensions i think you can get them on this site ?
  5. KY Longhunter
    KY Longhunter
    3,037
    Media:
    1
    178
    Aug 25, 2007
    Bowling Green, KY
    The diagram in post # 3 came from this site, but the bottom is cut off. Does anyone have FSM and can re-post entire diagram?
  6. bj40green
    bj40green Tssss, tssss
    3,163
    366
    Dec 13, 2010
    Playas del Coco, Costa Rica
  7. KY Longhunter
    KY Longhunter
    3,037
    Media:
    1
    178
    Aug 25, 2007
    Bowling Green, KY
    Thanks Rudi! Headed in the right direction...
    There is still a measurement I'm missing but I wil try and work from these.
    Alex
  8. voodoobillyman
    voodoobillyman
    68
    2
    May 18, 2011
    Houma,La
    I have a BJ41 and the measurements of the diagram in post 3 match the front frame width of my cruiser. Not the diagram from the FSM. I thinking the Cruiser sightly changed in 1980. I'm running 70 series axles and I had to move the long side front perch inboard to keep the shackles vertical. Seems that Toyota straight axles after the 80's track a little to the right. If my measurements were the same as what I find on mud and vintage off road ( I think they pulled them from tlc faq here) my shackles would have toed in instead of out. If you need me to measure mine to compare to the true parts of your frame let me know. good luck
  9. AlexJet
    AlexJet
    1,298
    5
    Jan 29, 2008
    Toronto, ON
    Does anyone have a full page of the image in post 3? It missing rear portion of the frame.
    I did looked at FAQ and Google it, but couldn't find full frame cross dimension image.
  10. KY Longhunter
    KY Longhunter
    3,037
    Media:
    1
    178
    Aug 25, 2007
    Bowling Green, KY
    AlexJet...never was able to find that page either.
  11. FJsnoozer
    FJsnoozer
    1,974
    41
    Apr 13, 2011
    Austin, Texas
    Any luck? I need to drill out my rear cross member this weekend.
    I guess worst case scenario I can measure from the spare cross member that I have.
  12. FJsnoozer
    FJsnoozer
    1,974
    41
    Apr 13, 2011
    Austin, Texas
    Rear is 2' 3 1/8" center to center. 1 5/8" center to back of cross member.
    The 79-84 cross member is quite a bit thicker than early models, which provides for more meat for the mount holes. I just drilled out the cups from my spare 80 cross member. I then placed them in my factory 77 rear crossmember.
    I have more measurements that i will document in my thread.
    Those diagrams were extremely helpful for all of my fabbed mounts.
  13. KY Longhunter
    KY Longhunter
    3,037
    Media:
    1
    178
    Aug 25, 2007
    Bowling Green, KY
    Snoozer, sorry I didnt reply but looks like you got it figured out. :beer:
    I never got that last page, as noted earlier in this thread.
