Charcoal Canister - Great Option!
Discussion in '80-Series Tech' started by Jeeper, Sep 7, 2010.
  1. Jeeper
    Jeeper
    220
    Media:
    2
    17
    Sep 6, 2007
    Nashville, TN
    All -
    After owning my 80 for over 2 years, experiencing higher than normal pressure when removing the gas cap the entire time, I tried many solutions. However, I've been reluctant to replace the charcoal canister due to the cost -- approx $300 (plus or minus), and it's a dealer-only item.
    Many of us have posted/read info on this thread:
    http://forum.ih8mud.com/80-series-tech/292965-excessive-fuel-tank-pressure.html
    I tried a junk yard canister from a 1997 80 with absolutely no affect. I tested hoses, attempted to test pressures, made sure the VSV worked correctly, etc. As best I could tell the system was at least functioning.
    After much research, I found this alternative canister for $36 !!!
    If the link gets stale, it's Autozone part VC120 for early 1990s GM cars with the 3.1L V6 (pontiac, oldsmobile). The dimensions were close enough to ours, so I pulled the trigger on a hunch. And it works beautifully! I wanted to run thru several fill-ups before I posted, and I can say that after 6 fill-ups, my 80 finally operates like a normal car (as the gas pump anyway). No sound, no air escaping, etc.
    It has the same style connectors and pulls in fresh air from the bottom just like the 80s. Using the highly calibrated "blow with your mouth" technique, I confirmed that this canister is almost identical to the stock 80s as described in the FSM. Minor details on mounting:
    • There is no hose connection on the bottom like the 80s, so you can remove the hose completely. This replacement canister has it's own filter and cover on the bottom. In stock 80s, the hose simply routes down to the frame area. I assume to pull in fresher, cooler air.
    • The diameter is just a bit larger than the stock 80s, but you can see in the pic below that it fits in the stock bracket, in the stock location, using the stock hoses. You'll notice that I used a ziptie in place of the bolt on the bracket - a longer bolt would be better, but I didn't have one around. And it's a tight fit, so I don't think it's going anywhere
    • The "tank" port on the canister uses a larger diameter hose barb, but a little persuasion works.
    Info/links:
    How to test your canister from 1997 FSM
    -I suspect that the purge check valve in my canister was sticking. You should have suction into the engine on the purge hose as described in the link above. This suction should be able to keep up with vapors generated in the tank as long as the canister flows freely.
    [​IMG]
    I haven't tested this after driving up to high elevations yet, but based on my experience so far, I think it's going to do great. Hope this helps out the community as much as it's helped me.
    L8Shift, FJ80Duo, Kaid000 and 4 others like this.
  2. gretzky
    gretzky
    12
    May 22, 2010
    Sweet! Thanks for trying it out and saving me $250+!
  3. AShoe
    AShoe
    209
    Aug 19, 2009
    Ft. Collins, Colorado
  4. unwiredadventures
    unwiredadventures www.unwiredadventures.com SILVER Star
    464
    2
    Jan 24, 2008
    Pasa Bernardino, California
    At that price, I'm going to try it.
  5. Flank
    Flank American by Birth, Texan by the grace of God.
    1,976
    144
    Mar 20, 2008
    Flower Mound, TX
    $#!T - I just plunked down for a new OEM one from CDan about 3 weeks ago...
  6. thestunts
    thestunts
    602
    3
    Dec 19, 2009
    Roseville, CA
    Great find !!
    guerasfj60 likes this.
  7. Nay
    Nay
    4,323
    33
    Aug 17, 2004
    Colorado
    I just installed my new OEM on Friday. :hillbilly:
    If this is a once a decade service, I'm cool with the high OEM cost. Keep us posted on how this one works for you, awesome at that price.
  8. cool breeze
    cool breeze
    2,279
    Media:
    70
    5
    Feb 25, 2007
    Colorado m'fing Springs!
  9. akarilo
    akarilo
    1,986
    37
    Jan 19, 2006
    Tulsa, OK
    Thanks for doing the leg work on this, as mine has been known to have an intermittent problem as well. Hopefully nobody on here will take the wind out of your sails by writing a 2 page dissertation on why they think it wont work. :D
  10. gotmud
    gotmud
    2,109
    7
    Jul 12, 2007
    Gilbert, AZ
    I replaced mine with an OEM last year...no change.
  11. Flank
    1,976
    144
    Mar 20, 2008
    Flower Mound, TX
    X2. OEM is king, but inexpensive aftermarket for not critical systems is prince!
  12. CycloSteve
    CycloSteve SILVER Star
    2,410
    Media:
    892
    273
    Mar 16, 2009
    Stuck between a rock and a hard place
    Other than the zip-tie mount, it also looks like it should pass most smog-inspections on the visual.
    :cheers: for finding a good low-cost alternative.
    Steve
  13. SUMMIT CRUISERS
    SUMMIT CRUISERS SILVER Star
    1,426
    184
    Mar 25, 2005
    Edmond, Oklahoma
    "I haven't tested this after driving up to high elevations yet, but based on my experience so far, I think it's going to do great. Hope this helps out the community as much as it's helped me."[/QUOTE]
    My only issues have been high elevations. Let us know your results after a high elevation wheeling trip. That would be of great help. Thanks for posting.
  14. sledge916
    sledge916 Media Partner
    1,561
    Media:
    1
    90
    Jan 22, 2003
    flagstaff, Az , 86004
    I tried to get one from Auto Zone just now and they said its not available, wonder whats up with that? Is there any other # you have for the CC?
    Thanks
    Seth
  15. Jeeper
    Jeeper
    220
    Media:
    2
    17
    Sep 6, 2007
    Nashville, TN
    Interesting.. I just ordered mine a month or so ago. Did you place the order via the website or at the store? I ordered from the website.
    Looks like rockauto has them for a few dollars more:
    1997 PONTIAC GRAND PRIX GT Vapor Canister
    Application seems to be:
    1997 Pontiac Grand Prix with 3.8 V6
    Keep us posted on your results!
  16. sledge916
    1,561
    Media:
    1
    90
    Jan 22, 2003
    I called the store, I also just tried to order online and it is not available, I clicked on the link above from rock auto and it list 3 part #'s which one is it? the VC 120 right?
    Thanks
    Seth
  17. pinoytoys
    pinoytoys
    376
    1
    Mar 30, 2010
    Orange County, Ca
    Nice! Great solution
  18. Jeeper
    Jeeper
    220
    Media:
    2
    17
    Sep 6, 2007
    Nashville, TN
    It looks like all 3 are the same - just different brands. Mine says "Rochester Products" on it. I would expect any vapor canister for this GM car application to work the same.
  19. fl4031003
    fl4031003 SILVER Star
    877
    Media:
    3
    45
    Apr 24, 2005
    Texas Hill Country
    great find
    Im at 6000ft with trips higher all the time. Keep us posted on your trip to high places! It would be nice to stop the gas smell in the garage after hot day trips.
  20. Romer
    Romer fatherofdaughterofromer Moderator
    10,146
    692
    Sep 14, 2003
    Centennial, Colorado
    I just ordered this. I hope its working for all of you. Thanks for finding it.
