Changing old center arm pivot for newer
Discussion in '40- & 55-Series Tech' started by Degnol, Apr 29, 2003.
  1. Degnol
    Degnol
    8,123
    Media:
    16
    6
    Jan 22, 2003
    Kansastitty
    I've got a '66 FJ40 and I'm about to add mini truck PS. I also want to change my old pin style center arm for the newer tapered-cone adjustable one. I've got a shim made for the front crossmember, and it looks like I just need to box part of the frame horn on the driver's side. Has any one ever done this before? The shim for the crossmember, should I weld it? Or can I use it as a shim and bolt it through with some Grade 8 bolts? The shim is solid, milled by a friend and will fit nice and snug. As for the boxing, I'm going to have a channel shaped piece bent to fit inside the frame horn, then weld it top and bottom.
    OK, grade my paper here...BEFORE I screw up.
    Thanks,
    Ed
