changin the clutch
Discussion in '40- & 55-Series Tech' started by eli77fj40, Dec 19, 2002.
  1. eli77fj40
    eli77fj40
    21
    Aug 25, 2002
    Does anyone know what the bare minimum amount of stuff(seats,tank,heater...) is necisary to change the clutch. Also does anyone have any low-tech ways of pullin the tranny for this project with the top on?
  2. Mavric1298
    Mavric1298
    163
    Oct 28, 2002
    Not sure about 40's but in 60's you just have to buy/rent a tranny jack, and pull the carpet back enough to let you remove the "hump" or whatever you wanna call the acess pannel, and pull a few things off from the top, then lower it on down, look in the haynes manual if you have one, i thought it was pretty good at discribing it
  3. woody
    woody Internet Fireman Staff Member
    10,333
    Media:
    303
    1,089
    Jan 15, 2002
    Toquerville UT
    Move heater, pull passenger seat, slide/move fuel tank, remove tunnel cover
    I used to bench press the FJ40 4-speed and t-case into place, but I tend to get a bit stubborn with those things. I've used a normal floor jack and a web-ratchet too.
  4. Erics75
    Erics75
    81
    Jun 14, 2002
    Ahh, the good old days, I too used to bench press them in and out. Now I have $30,000 worth of titanium in my back and this month is my 4th year aniversary since the injury and in February will be three years off of work. Use a jack and have somebody help you.
    Eric
  5. Bailey
    Bailey
    55
    May 24, 2002
    77 FJ-40 "bare mimimum" -
    Transmission shifter, Transfer Case shifter, rear drive shaft, emergency brake, transfer case.
    Find some bolts that are the same thread pattern - but about 6 inches long and replace the transmission bolts with these one at a time. Slide transmission aft to free transmission shaft, support the transmission from below, remove the "slider bolts" then angle the transmission down in back to clear the frame.
    Do the reverse to install. Probably about a 3 hour job the first time you try it. 2 with experience.
