chainsaw troubleshooting
Discussion in 'Workshop and Home Improvement' started by MoJ, Jul 22, 2007.
  1. MoJ
    MoJ Moderator
    3,287
    54
    Oct 24, 2003
    My Husqvarna does not want to start. It ran great yesterday but wouldn't start later in the day and still won't this morning. Here's what I've checked.
    -Spark - good
    -Fuel filter - good
    -Fuel arriving at carb - good
    -Air filter - good
    -Compression - good
    -Chain brake - good
    I tried using starter fluid but it still wouldn't start at all. The chain move freely on the bar and the brake appears to be working correctly.
    It's always been a good starter and is less than a year old.
    Any suggestions?
    Thanks,
    Jason
    (As a side note - I really should have taken advice and used a local mom and pop rather than buying it from Lowe's. Even though I had a gift card for Lowe's it has not been worth the hassle of dealing with their 30-day return policy. Despite showing them receipts detailing my purchases of $3k there in the last week they would not let me return or exchange the saw and treated me like crud through the whole process. From now on I'll only purchase outdoor power tools from places who have the ability to make exceptions to the policies that their store manager has tatooed on his forehead.)
  2. sirenmoses
    sirenmoses
    3,284
    2
    Dec 12, 2006
    7400', central NM
    How many hours have you run it/tanks of fuel used since purchase?
    Not starting w/good spark etc: does it 'try' to start (cough a little) or does it seem as tho it's not even catching? Sometimes a quick cleaning of the spark plug tip helps.
    Another thing you could try is to start it w/o air filter on. If it runs then get it to idle smoothly before replacing filter.
    Find a husky dealer & have them troubleshoot it. Husky warranty might still cover even tho big box won't touch it.
    Good luck! HTH
  3. fj40charles
    fj40charles
    3,040
    195
    Dec 7, 2002
    Texas
    I would try another Lowes and speak to the store manager. I had a problem once on a craftsman chain saw. I would not start, I took it apart and saw that a piece of small wood was stuck on the reed valve keeping it open.
  4. Cuerno Largo
    Cuerno Largo SILVER Star
    912
    111
    Apr 20, 2004
    Lakehouse
    Triple check the chain brake. I'm not saying this to be a smartass and I know you probably did, but several times I thought mine was off and after I did troubleshooting on everything else, I went back to the chain brake and it was on when I thought it was off. :cheers:
  5. splitshot
    splitshot Head cook, Bottle washer, and Peace keeper. SILVER Star
    6,259
    Media:
    11
    454
    Nov 17, 2006
    Rodent Central, Az
    Is the plug wet after pulling on it awhile? I've also had issues on reed valves.
    Where's D' Animal when you need him?
  6. Capt. Jim
    Capt. Jim
    2,149
    33
    May 1, 2005
    West Palm Beach, Florida
  7. Dave-T
    Dave-T
    1,546
    1
    Oct 30, 2006
    Heber City, UT
    What model husky is it?
    Will it start or sputter as you play with the choke? Sounds like a simple carb issue to me but you may have blown a seal that caused an air leak big enough it won't run.
  8. MoJ
    MoJ Moderator
    3,287
    54
    Oct 24, 2003
    Update
    Model 142.
    Ended up taking it to the wty service center. Everthing checked out, including the proper fuel mixture, until he checked the compression. It was 1/3 of the min factory spec. Piston is likely toast. The tech had to call Husky so I'm waiting to hear back.
    In the meantime, today I went to a local independent Stihl dealer. As an act of personal revenge against Lowe's and Husky I purchased a MS-290-18 Stihl Farm Boss. I'm sure the Husky will be fixed under warranty but I've already wasted enough time screwing around with it and have a large cutting project ot get done. I'll have the Husky fixed and then ebay it.
  9. Dave-T
    Dave-T
    1,546
    1
    Oct 30, 2006
    Heber City, UT
    I thought you said the compression was good!? How did you check it initially? One of my saws is a farm boss. Great saw, it pulls a 24" bar pretty well in soft wood (full skip of course).
  10. Klunky Chris
    Klunky Chris
    1,070
    Nov 5, 2003
    Shippensburg PA
    truly...
    I'm trying to figure out how a 1yr Husky pukes a piston :confused:
    Please tell us what they find
    love my 455 Rancher Tool-less
    [​IMG]
  11. MoJ
    MoJ Moderator
    3,287
    54
    Oct 24, 2003
    I checked it but did not have the correct factory spec to compare it to.
    I had the same question until I learned that the e-142 sold at Lowe's is really a Poulan with the Husky name on it - Apparently an attempt to take advantage of their brand reputation but still be able to sell a $199 saw at Lowe's. I could have saved myself some money and bought a $99 Poulan at Walmart that would have been just as equally crappy. :mad:
    The 455 Rancher is nice. If it hadn't been for my experience with Husky and their overpriced Poulan 142 I would have considered it since it's actually made by Husky.
  12. stayalert
    stayalert SILVER Star
    1,725
    172
    Sep 28, 2004
    Norwich, VT
    my 455 starts with the chain brake on what's the dealio?
  13. alex e
    alex e
    1,798
    14
    Apr 1, 2006
    Dallas
    Can't a piston get f'd in a year by running it in really dirty conditions thereby sucking a bunch of crap into the saw past the filter and scoring the piston?
    As far as rebranded Poulan, stay away for sure. Get a real Husky and you'll be happy. Stihls kick some ass too though....044, 066, etc. I bought an 80s-90s Husky 181 XP from KliersLC for $150 and it runs like a raped ape.
  14. D'Animal
    D'Animal Rescuer of Beagles & Landcruisers Moderator
    21,114
    Media:
    180
    223
    Mar 31, 2006
    Central California
    Dang! I just found this thread.
  15. D'Animal
    21,114
    Media:
    180
    223
    Mar 31, 2006
    Central California
    Electrolux of Sweden owns:
    Husqvarna
    Poland
    Partner
    Pioneer
    Jobu
    Johnsered
    McCullough (Titan Series)
    Komatsu Zenoa (Redmax)
    All of this product is sold under the Husqvarna name and much of it is in Sears and the fast movers are sold in Lowes.
  16. inthewall
    inthewall
    1,304
    7
    Apr 10, 2006
    Elko, Nevada
    Not pre-mixing the right amount of 2cycle oil can cause a piston to go out in a year.
  17. splitshot
    6,259
    Media:
    11
    454
    Nov 17, 2006
    Rodent Central, Az
    How's the leaf blower exhange thing going?
    Any talk on the horrizon of putting 4-strokers in our saws?
  18. splitshot
    6,259
    Media:
    11
    454
    Nov 17, 2006
    Rodent Central, Az
    That is very true...
    I live by another rule also, don't lend your saws to anyone. I've got a husky 51 that I loaned w/ a new batch of fuel mix to an ex-employee. After runng though my mix, it was fed straight gas.:mad:
    And then there was the person that borrowed my backup saw and was too cheap to go buy a gallon of fuel (I gave them the 2cycle oil), and thought they otta use up that mix that was in the garage for two years...
  19. fj40charles
    fj40charles
    3,040
    195
    Dec 7, 2002
    Texas
    There are certain things you don't want to loan out. Wife, underwear, welder, and good tools.
  20. D'Animal
    21,114
    Media:
    180
    223
    Mar 31, 2006
    Central California
    People traded in 1,500 old dirty emmission Back Pack Blowers in six days.
    It went very smooth.
