Thanks for the info. Here is an update. Fuse is good. When shifting from N to L I can hear the relay "click" and the CDL actuator "whine". When I shift from L to N I can hear the relay "click" and the CDL actuator "whine". When I shift from N to H or H to N I hear nothing. Is this typical that the relay/actuator only engage between N and L? CDL interlock remains locked and ABS remain disabled. Any help appreciated. Oh, also tried shifting from H-N-L about 1000 times, drove F and R repeatedly, nothing seems to unlock CDL.
If this doesn't work or isn't available, try putting it up on some 6 ton jackstands (all 4 corners off the ground), and put it in gear (forward and then reverse) to see if it will release that way. Be VERY careful with this one, potential for bad things to happen is high. Don't be under the truck for this step.
If you get this to work, I'd lock it again, and unlock it again, and lock it again, and so on till you're confident it's working properly.
Have you changed the TC fluid? I've always found the CDL engages and disengages faster with some fresh fluid in there, in both my 80's and the wife's GX470.
uncle banjo, what do you mean by fluid is a good idea?
The actuator motor is a sealed unit, so the binding is really more internal.
Its all good! Lol I probably should have been more descriptive!I thought you were meaning spray it with WD40 or something. Sorry.
So i am having the same issues. It will not disengage the center lock. I have tried everything listed here. Changed the fluid, figure 8's, reverse 100 times switching gears etc. Its still locked. I can hear it click from low to n. Than when I go from neutral to high, center diff lock still is on and Iocked. Im guessing a bad actuator. I have no clue where that is. So if anyone can show me a few pictures so I can check it out and possibly change it out i would appreciate it.The actuator moves the fork in the photo to lock onto the front shaft.
The problem is if the shaft is stuck or if the actuator is bad you really need to remove the TC to troubleshoot.
Hopefully it will disengage itself while driving around or as mentioned above, jack up all four corners to relieve any torque on the shafts.View attachment 1147255
Did you try what was suggested in post #15?So i am having the same issues. It will not disengage the center lock. I have tried everything listed here. Changed the fluid, figure 8's, reverse 100 times switching gears etc. Its still locked. I can hear it click from low to n. Than when I go from neutral to high, center diff lock still is on and Iocked. Im guessing a bad actuator. I have no clue where that is. So if anyone can show me a few pictures so I can check it out and possibly change it out i would appreciate it.
What us post number 15? New to this siteDid you try what was suggested in post #15?
Yes i did try that. Still no luck at all! I'm guessing its the switch that triggers is. Just not sure of the location of it, or what it looks likeDid you try what was suggested in post #15?
