Center diff not locking in low
Discussion in '80-Series Tech' started by kstone, Jun 14, 2003.
  1. kstone
    kstone
    46
    Apr 12, 2003
    At least the light does not come on. What should I check first?
  2. Cruiserdrew
    Cruiserdrew SILVER Star
    13,603
    1,527
    Mar 15, 2003
    Sacramento, CA
    Check the sensor that tells the transfer case it is locked. My buddy had one go bad at 180k and it wouln't let his diff locks work either. Pretty easy and straight forward fix as I recall. You might jack up all 4 wheels and see if the transfer is actually locked in low range. If it is, the sensor is your problem. Are you sure the light isn't burned out?
  3. kstone
    kstone
    46
    Apr 12, 2003
    It does not feel like the xfer case is locked - I dont think it is. Actually kind of cool - no binding in tight turns, I'm going to get that switch now.
    But I do need to fix this problem, its a 96 with 90K miles. Any other ideas?
  4. Photoman
    Photoman SILVER Star
    1,145
    Media:
    41
    47
    Mar 28, 2003
