Cat heat
Discussion in '80-Series Tech' started by Keep, Apr 11, 2003.
  1. Keep
    Keep
    251
    1
    Mar 27, 2003
    Chapel Hill, NC
    How hot is too hot? My carpet got a bit wet and after 20 minutes of driving I had some steambath action going on in the truck. :eek: Quite a visible amount of steam rising from the floor.
  2. semlin
    semlin rocker
    5,209
    Media:
    1
    324
    Mar 27, 2003
    north of 49
    been there, seen that... my rubber floor plugs under the carpets are also melted and distorted. I assume that's life...
  3. Wrench
    Wrench One Bashed Up 80
    4,496
    179
    Mar 27, 2003
    What year do you have? I believe there should be a metal shield above the cats.
  4. Keep
    Keep
    251
    1
    Mar 27, 2003
    Chapel Hill, NC
    94... there is a metal shield. I hate the thing.... little rocks tend to get stuck in it and rattle around driving me crazy.
    On a positive note I finally settled on the ARB bar after talking with Christo about ARB vs. the Slee bumper. Its installed and I'm loving it...and it looks fantasic with the ARB+black flares+Slee rear bumper. Of course we don't care about such things... so long as its functional. ;)
  5. landtank
    landtank SILVER Star
    18,425
    601
    Mar 27, 2003
    Groveland MA
    You might want to watch those cats. If I'm not mistaken you do not have an OBDII system. Hot cats are usually the first sign of becoming plugged. In an OBDII system there is an O2 sensor fore and aft of the cats to see this condition. In yours it is blind to that.
    Rick
    BTW the second sign is usually either burnt valves or fail head gasket.
  6. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Somewhere in the foothills...
    Keep & semlin,
    I've heard that others have installed a heat shield type material under the right side carpet. Some of that foil + insulation material. Maybe check availability at race shops. At least it helps keep the heat out of the cabin.
    -B-
  7. Keep
    Keep
    251
    1
    Mar 27, 2003
    Chapel Hill, NC
    I'll definitely check to make sure its not getting plugged... and I'll think I may look into the heat shield material too. Thanks.
  8. Wrench
    4,496
    179
    Mar 27, 2003
    Keep, If you don't mined me asking why did you settle with the ARB not Slee's? Dosn't Slee have better aproach angle?
  9. Keep
    Keep
    251
    1
    Mar 27, 2003
    Chapel Hill, NC
    It was actually a very a tough decision.  I would have gone with the Slee bumper, but the wildlife factor played a big part. Lots of deer around here.  I also wanted the option of running big lights like Hella 4000s.  The ARB provides better protection and has enough room for bigger lights, but at the expense of approach angle, and iof course the unique factor... Everyone has an ARB, that makes Christo's a bit cooler. I'm happy with my choice though... and I'm relieved to have finally decided on one.  :G
  10. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    Is there a way to tell if it is pluged or getting there?
    The 94 doesn't have the rear o2 sensor.
    What problems would there be if I just cleaned out the cats with a long big punch? Is there a need for back presure from the cats for the motor to run right? What damage would there be to the motor?
    kurt
  11. semlin
    semlin rocker
    5,209
    Media:
    1
    324
    Mar 27, 2003
    north of 49
    I second landtoy's question. How do I figure out if the cat is blocked. My upper heat shield is installed.
    So just so I'm clear, am I in the minority in having a hot passenger side floor pan, esepcially after a long drive?
  12. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Simon,
    You might be in the minority but you definitely are not alone. Many have reported heat on the PS floor from the cats, especially on the 91-92 models. I believe later models came with more insulation and maybe better heat shields. Later models also have dual inline cats.
    -B-
  13. landtank
    18,425
    601
    Mar 27, 2003
    Groveland MA
    Back in the day you could buy a test pipe to swap in place of the cat to see if there was a performance difference. How's your gas mileage?
    Rodding your cats from what I've read only affects your emission output. Not first hand info but there was something on the SORry board.
    Rick
  14. semlin
    semlin rocker
    5,209
    Media:
    1
    324
    Mar 27, 2003
    north of 49
    How's my gas mileage? Brutal but not hugely out of line with others. Converted into usg it's about 9.5 mpg in winter on a five3 mile stop and start daily commute, and up to 14.5 on a straight highway run.
  15. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    In Australia the 1FZ doesn't have cats nor EGR. I can't see why I couldn't remove them as I don't have a rear o2 sensor. The hard part will be making test tubes. Could put a bar through the cats but it will be very$$$ to replace them. Maybe a after market cat could be used and relocate it down stream. Like a place where it wont get crushed. What could go wrong not having the cats?
    kurt
  16. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,605
    2,983
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    I suppose you could do that..........if breaking the law doesn't trouble you..........................................................
  17. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    Looks like there is a back presure tool to install into the o2 sensor hole to check back presure. Less than 3 lbs is what the site said is not plugged.
    kurt
  18. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    >> if breaking the law doesn't trouble you... <<
    And a Federal law at that; not some local ordinance.
    -B-
  19. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    The worst they can do is make you put a new one on. I can say that the last owner did it. Oooppps I hope big brother isn't reading this.
    I am not kurt if big brother is out there.
  20. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Kurt,
    "Under federal law, the maximum fine for removing a catalytic converter from a vehicle is $2,750 per vehicle. The person who was responsible for taking the catalyst off would also be required to put an appropriate catalyst back on."
    They can easily find out who the PO was. Lying to a federal officer might bring additional penalties. I doubt that any "EPA police" would ever find out or that they would enforce the maximum fine. However, it *is* the law of the land.
    -B-
