Carb'd Chevy 350 Question - Carb backfire (1 Viewer)
El Dorado County CA
My 40 has a 78 350 installed. I run a Rochester 2 barrel carb. There is no smog stuff on it. Recently when running at moderate rpm, say 2000, engine is warm, when I put my foot into it the engine will sneeze through the carb.
My stock 40 used to do this and the solution was a new gasket around the accelerator pump, as I recall.
The only PM I have done is fluid changes, air filter and plugs. The PM was done months ago.
I run regular CA fuel.
Should I check the timing or might something be wrong with the carb?
The choke is OK and not stuck closed.
Thanks,
BigJim
my 72 chevy 2 wheel drive long bed with a 350 with a 2 barrel carb does this with bad gas. We just picked the rig up so i plan to get a carb "rebuild" kit. and do the gaskets and new filters for it! Mine only did it around 50-60 MPH. and only when in drive. when i ran premium it stopped doing it so much but still did a little!
Similar threads
