Hey guys, I just finished a rebuild put everything back together and now it won't start. Set it to tdc no.1 spark plug and it won't start, any ideas?
Shouldn't the rotor be pointing to #4 plug when you are at 9 deg TDC?It's most likely the distributor has skipped a gear when re-installed.
With #1 cylinder at top dead center, distributor installed with the rotor pointing at the #1 plug wire. No fire, remove distributor and rotate the rotor 180 degrees and reinstall.
While cranking make sure oil pressure registers on your gauge if not re-install distributor. Another thing to check is the fuel delivery to the carb, it takes several cranks for the fuel to reach the carb. Check all electrical connections as well.
There are many threads on this topic try the search function or google it.
