Can you switch reg. doors w/ Amby's?
Discussion in '40- & 55-Series Tech' started by jford, Jul 23, 2003.
  1. jford
    jford
    49
    Jul 9, 2003
    Simple question... Can you switch swing gate and hatch with amby doors? I realize that you would have to put a hinge on the top, but does one of the bottom hinges line up? Thanks
    Jford.
  2. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,778
    308
    Dec 13, 2002
    Knee deep in hookers and gin
    I do not believe the lower door hinge holes line up. You also need a different crossmember at the top and the latch hardware at the bottom.
  3. jford
    jford
    49
    Jul 9, 2003
    Ok, I can see that, but do they match up with the top and tub? I figured on some mods to the hinges, and what not. I'm looking to buy one that doesn't have amby doors, but at some point would like to convert.
  4. Gumby
    11,778
    308
    Dec 13, 2002
    The big square hole in the back of the truck is the same size once you take the doors out.
  5. xumFJ40
    xumFJ40
    376
    May 9, 2003
    Tex..as...Ohhhh...Texas!!!
    So the real question is...
    Is there a more astetically pleasing option for a '75 plus w/o a hard top than the aluminium rectangel that covers the amby void?
  6. Gumby
    11,778
    308
    Dec 13, 2002
    Fit a pair or quarter doors or try and find an old tailgate style. Or weld two quater doors together to make the old tailgate style.
  7. offcamber40
    offcamber40
    279
    1
    Apr 26, 2003
    Mountains of WV
    I agree with what gumby just said. I just bought a set of pre 75 half door with all hardware for about 70.00. Thats the same price as one of the filler panels.. I have to do a little rust repair and spray them, but I think it will be a much nicer appearance. The lower hinges will have to be drilled, and a couple of other holes, but other than that, it looks like it will be a fairly clean install..
    Hope this helps,
    Mike
  8. xumFJ40
    xumFJ40
    376
    May 9, 2003
    Ok...because that is what I was thinking about doing. I guess that I was confused by the start of this thread and thought someone was saying the the pre '75 dutch style doors would not fit on a later model.
    Thanks
  9. Gumby
    11,778
    308
    Dec 13, 2002
    You would need to drill new holes for the hinges and a hole in the floor for the inner door latch, otherwise they fit.
