Calculate the length of a coil spring??
Discussion in 'Chit-Chat' started by Etsha6, Mar 16, 2006.
  1. Etsha6
    Etsha6
    Apr 7, 2005
    34
    Anyone know how to?
    I need to know the length of bar/wire needed to form a spring.
    Anyone know of a formula?
    Not interested in Hookes Law or simple harmonic motion or any other spring formulas, just the actual length of the wire used to make the spring.
    Thanks
  2. denis
    denis (O) toyota nut (O) SILVER Star
    Nov 11, 2002
    1,154
    buried in a pile of yota projects
    number of spires * Pi * centerline diameter
  3. Etsha6
    Etsha6
    Apr 7, 2005
    34
    Thanks Denis,
    That would give a close approximation for a thin wire spring with coils close together.
    Im looking to calculate the length when the coils are not close together, say one coil revolution per 3 x diameter in axial length. ie like a very stretched spring.
  4. denis
    Nov 11, 2002
    1,154
    OK. say you unroll just one coil like you would a cylinder. now you have a basic straight wire with a length that equals the hypothenuse of a right-angle triangle with a base length of Pi*D and a height of H = 3xD.
    So you have L = D x sqrt(Pi² + 9)
  5. WristPin
    WristPin
    Sep 14, 2005
    2,722
    The NW, Cascade Mountian Range
    so theres such a thing as Hookes law???
    gonna have to research this one.
    wouldnt the combined energy of the coil multiply the initial winding of the corresponding friction threshold?
    regardless of pi??
    if you multiply lenght of wire times height of coil time pi, the appiled resistance
    it will be one third less than the desired wieght distributing area.
    area time force equals pressure.
    wait, that another law...
  6. denis
    Nov 11, 2002
    1,154
    all bets are off with a stretched coil since we can't consider the bending forces as negligible.
  7. Etsha6
    Etsha6
    Apr 7, 2005
    34
    Eureka!
    Answers are much clearer when the question is conceptualized clearly. Now to check the algebra!
    Thanks
Share This Page
