Bypassing heater all together??
Discussion in '40- & 55-Series Tech' started by 78crzr, May 22, 2003.
  1. 78crzr
    78crzr
    657
    1
    Apr 6, 2003
    Tomball, TX
    I began pulling the seats, console, gas tank cover, etc. out of FJ to replace the transmission cover.  In doing so I seem to have ruptured a cheesy fix the PO did on one of the front heater tubes and began leaking coolant.  How can I just bypass the entire heat/ vent system completely? I'm leaving for an off-road event tomorrow and need to get the thing back together tonight.   Don't have time to mess with repairing the tube today so I want to just pull the entire heater, etc. out and fix another weekend.  Can I simply connect the two hoses leading into the heater tubes on the engine side of the firewall to bypass it completely?  Will it hurt to have coolant just circulating through that set of hoses without going through the heater? :eek:
  2. woody
    woody Internet Fireman Staff Member
    10,336
    Media:
    303
    1,099
    Jan 15, 2002
    Toquerville UT
    yep, just connect the two....
    or, if yer like me on my Chevy motor, ya pull the fitting off the water pump and install a plug then pull the return off the intake and put a plug there too....
    heaters are overrated...hehehe
  3. wayne_fj40
    wayne_fj40
    252
    Dec 31, 2002
    Yes you can do that you just won't have any heat.easy temp fix :G
  4. Ky-Hoosier
    Ky-Hoosier
    7
    Feb 19, 2003
    Cut hose intwo at the site of leak, insert a snug fitting bolt into each hose, screw on hose clamps and continue to cruise. Or better still insert a piece of copper tubing and clamp for a Kentucky permanent fix.
