#1: Never try to turn the key when there's pressure on the steering lock. We've all probably done it but this leads to breakage of the lock cam. AFAIK there is zero field fix for this. Even if you have the new part getting the anti-theft bolts out in the field would be more PITA...not impossible mind you but something I recommend, after witnessing what this issue is all about on Rusty's '98, doing as a PM measure.
#2: Per Rusty_tlc's thought: Removing the steering column, which involves 4-screws and removal of the lower cross-over air duct, and electrical connectors makes the job easier overall. One person can remove the column but two need to re-install it. After helping him do his I will be pulling the column when I upgrade mine to the redesigned and strengthened part. I'd love to eliminate the steering lock feature...not sure if its as simple as grinding off the lock cam or not. I'll experiment with this when its on the bench with the old part.
#3: We didn't use the anti-theft style bolts that retain the collar assembly to the steering column but rather socket cap style bolts of the same thread and length. I plan to do same just in case it has to come apart in the future for whatever reason.
HTH.
HTH.
