bump steer
Discussion in '40- & 55-Series Tech' started by preacherman, Sep 19, 2003.
  1. preacherman
    preacherman
    235
    Oct 1, 2002
    Midland Texas
    Question,
    My fj60 has a bds 2.5 inch lift with sor 1 inch lift shackels. When I installed the lift and shackels I did not install a shim ( I was hoping I would not need some with only 1 inch shackles) But now I am having some bump steer issues. My question is how much bump steer is common with 3.5 inches of lift and 33's and what could be fixed by shimming the front. Also if I shim the front will I need to get it re-aligned? thankx
  2. woody
    woody Internet Fireman Staff Member
    10,336
    Media:
    303
    1,098
    Jan 15, 2002
    Toquerville UT
    bump steer is usually the result of your drag link and your tie rod no longer being parallel. A drop pitman arm is normally the fix.
  3. fsusteve
    fsusteve
    3,802
    Media:
    18
    49
    Aug 2, 2003
    Naples/Big Pine Key, Fl
    You will need the shims, 2.5 degree ones I believe. I would see how it drives after before I would bother with an alignment, mine didn't need one. Steering geometry is everything. :cheers:
  4. preacherman
    preacherman
    235
    Oct 1, 2002
    Midland Texas
    I think I will try the shim 1st. Where can I find a drop pitman arm for a 60. I have seen tons for the 40 but none for the 60. Are they the same length and spline? ie will a drop for the 40 fit a the 60?
  5. erfworm
    erfworm
    348
    30
    Apr 10, 2003
    I myself would also be interested in any source for a dropped pitman arm for a 60/62 :D
  6. Overlord
    Overlord
    485
    Feb 19, 2003
    Wasilla, AK
    what are the symptoms of bump steer? I've have steering problems ever since I put in the 2.5" BDS lift w/ stock shackles. It wonders all over, sometimes to the left and sometimes to the right. Mostly of the time she just wonders to the left (driver side).
  7. s79bj40
    s79bj40
    359
    Feb 10, 2003
    Brisbane
    it would be under compression or a bump for left hand drive vehicles the car will go right and opposite for right hand drive vehicles? Its to do with the change in difference in height between the axle and the chassis at the steering linkage. Wandering could be worn or loose components or worn front tyres.
  8. Overlord
    Overlord
    485
    Feb 19, 2003
    Wasilla, AK
    [quote author=s79bj40 link=board=1;threadid=5441;start=msg44402#msg44402 date=1064411947]
    [/quote]
    The tires a newer and the pressure is ok, so it isn't tires. What components should I check out? I haven't got it aligned yet, so should I do that first? Caster might be off... ???
  9. theo
    theo
    1,432
    Feb 19, 2002
    [quote author=Overlord link=board=1;threadid=5441;start=msg44389#msg44389 date=1064410383]
    [/quote]
    Check the caster. My friend had the same sysmptoms and used shims to correct it.
