^^^^ simply sealing the wood with poly or other will prevent this. Just apply a couple coats before carpet.
Is there a specific reason you used birch? Thanks.
Thousands upon thousands and thousands of in and out cycles on this and no visible wear other than UV damage.I’m very happy with it in my drawer build also. During the build I tested UHMW on UHMW and it actually seemed to have more resistance than UHMW on wood. I used 3 flat strips underneath the drawer, no corner pieces. It is definitely not effortless like heavy duty ball bearing slides tho.
Seating space?Would like to build some but don't want to give up the space. Decisions decisions!?!?
Did u add the L shaped plastic to not the drawer and the base(box) or just the box?? I love this designLike the title says, I built some drawers over the weekend. nothing real fancy. I took a lot of ideas from other drawers that have been posted up but went another direction when it came to the slides.
I have a couple sets of 26" Accuride heavy duty ball bearing drawer slides I was going to use, but a wanted more depth and to be able to easily remove the drawer if I wanted. So I ordered up a 10' stick of UHMW L-Angle from usplastics.com. 3.71 a foot. I know similar has been done before, but I figured I post up my take on the stuff.
Exact stuff I used: 1/4" Thick x 1-1/2" L x 1-1/2" W UHMW PE L-Angle | U.S. Plastic Corp. - http://www.usplastic.com/catalog/item.aspx?sku=46061&catid=868
My drawers measure approximately 31.5" deep, 20" wide, and 11" high. Pretty **** big. I left a long cubby directly behind the second row. The plastic runners work really well. Doesn't side quite as smooth as ball bearings but for the price it can't be beat. I would definatly recommend using this stuff instead of forking over the cash for ball bearing slides.
I'm about 75% done with them. I have a little fine tuning to do with wood filler and sanding then I'm going to spray it with tan Al's Liner. The drawer faces are going to get stained and cleared.
It is only where you see it in the first pic of the thread.Did u add the L shaped plastic to not the drawer and the base(box) or just the box?? I love this design
UHMW is used as chain guides on chain conveyors all over the world. It's the slickest stuff in town. If you really want to impress the cool kids use Murtfeldt green:
FWIW, using two pieces of similar material for "frictionless" sliding won't work. Cohesive forces build up and you get sticky, not slidey.
I used candle wax, works great and no mess.I wonder if you could put some kind of slick stuff on the bottom of the drawer or cabinet to help stave friction when they become loaded? I'm envisioning the middle of the drawer bowing and making contact with the cabinet, making it more difficult to slide them out when full.
I love the idea, work and craftsmanship! Great job!
