Buick 225 distributor question
Discussion in 'Jeep' started by Campfire, Jul 18, 2009.
  1. Campfire
    Campfire
    653
    Media:
    45
    11
    Nov 6, 2005
    Napa, California
    My son's 51 Willys just received a 225 V6 transplant. It's a great little engine and runs OK, but I have that missfire on the right bank. I think I have the wrong cap on the distributor and don't trust the replacement parts.
    Does anyone know if the point distributor caps had the long odd spaced contact points in them like the HEI caps?
    And yeah, that little air filter is going away...
  2. D'Animal
    D'Animal Rescuer of Beagles & Landcruisers Moderator
    21,116
    Media:
    180
    223
    Mar 31, 2006
    Central California
  3. ajfriz
    ajfriz
    555
    Mar 4, 2003
    225s are all odd-fires IIRC. When they went to the 231 it was even-fire (although there were a few 231 odd-fires when they first started producing them). It's always going to sound like it has a miss when it is at idle.
  4. Campfire
    Campfire
    653
    Media:
    45
    11
    Nov 6, 2005
    Napa, California
    Thanks for the replies, and I've joined the EarlyCJ5.com forum to have a little more direct access to the clan. I found that we had clocked the plug wires "one" over to get the vacuum advance to clear. Wrong move, with that 45/75 degree firing thing. I pulled the distributor out and reset it it two teeth over and now everything clears and fires on the right side again. On to sorting out the carb or just ordering a Holley 2300 2 barrel.
  5. D'Animal
    21,116
    Media:
    180
    223
    Mar 31, 2006
    Central California
    Glad it worked out for you.
    I'm sure I will have a ton of questions when I start on my 225 in my 1968 Commando.
  6. Campfire
    Campfire
    653
    Media:
    45
    11
    Nov 6, 2005
    Napa, California
    What are you running for induction? We have an old Rochester 2CG on there, but it's worn out the throttle shafts. I'm about ready to order that Holley 2300 so we can change the jets easy at elevation.
  7. D'Animal
    21,116
    Media:
    180
    223
    Mar 31, 2006
    Central California
    My rig is 100% stock, so what ever they came with off the assembly line.
    Mine still has the smog pump on it from 1968.
