Broken Weld
Discussion in '80-Series Tech' started by 92Cruiser, May 23, 2003.
  1. 92Cruiser
    92Cruiser
    121
    Mar 28, 2003
    The hanger above my cats keeps snaping off. I've had it welded twice now and the hanger finds a new spot to break every few months. Anyone else have this problem or have a solution? It's driving me crazy. Once it breaks, all I hear is clatter from under the truck.
  2. Hltoppr
    Hltoppr SILVER Star
    2,022
    Media:
    4
    4
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    Haven't had the problem myself. Have you checked the other hangers? If there is excess movement somewhere, that might be causing the weld to break.
    -H-
  3. yomama
    yomama
    291
    Mar 27, 2003
    Or you may also have a motor or trans mount that has too much free movement and needs to be replaced. If the engine can move too much it will cause them to break.
    Yomama
  4. Jim_Phillips
    Jim_Phillips
    723
    1
    Mar 27, 2003
    Ingerland
    Also check to see whether the exhaust is welded / fixed solid at any point - I had a heat shield installed and someone welded it to the exhaust. As a result the exhaust couldn't move freely / vibrate and hence broke at the hang points...
    Jim
  5. 92Cruiser
    92Cruiser
    121
    Mar 28, 2003
    How do you check for broken Trans/Motor mounts?
  6. Wrench
    Wrench One Bashed Up 80
    4,493
    179
    Mar 27, 2003
