First post here, and I may need a hand. I had some gear oil leaking out of my T-Case, externally from the big O-ring and internally through the speedo cable itself. I ordered both seals but had difficulty separating the electrical pickup / sensor portion from the gear driven portion that goes into the T-Case....as you'll see in the pic, they're still attached. Anyhow, while cranking on the two I broke the nose of the gear driven part. I checked the website that I normally go to for hard to find stuff [Lakeland Toyota Parts Overstock] but that part is not available. Does anyone have one lying around, maybe from a T-Case rebuild? In the meantime, I'm going to go out on a limb and put the shaft back in - I think there's still enough material in the nose to keep it spinning without any further damage...fingers crossed. Thanks in advance for any assistance or ad
vice!
