Hi All,
I broke off my Petcock Radiator plug. I wan to fix it myself. I tried to use a sliver braze solder wire with a benzomatic propane torch but it would not heat the surface to melt the silver braze solder. I therefore had to use regular solder for plumbing of copper pipes. The torch heated the radiator enough to melt the solder but it was too weak.
Home Depot people did not know anything about brazing.
I think I will now try with this torch: Bernzomatic OX2550KC Oxy/Map-Pro Torch Kit-331673 - The Home Depot
Do you think this will be hot enough to braze the OEM FJ40 radiator? This actually comes with brazing rods.
Also I need to bend my sm465 shifter and my AA 4wd high and low dual shifters as well. Do you think this torch will be hot enough for that too?
From what I have read on the web it should work for both but wanted to get a experst opinion on the site.
