- Thread starter
- #21
Bleed order should be MC, RL, RR, FL, FR Always go from the farthest away to closest. If you look at how the lines run you will see which is the greatest distance.
Dynosaor
Woops, Dynosoar is right, that is the order I did it.
Try manually adjusting the rear brakes out till they are touching drive down the street, recheck to see if they are still touching. If not adjust out a few more clicks until touching. Drive down street. Repeat. If you are having the same problem I am, keep manually adjusting out till the pedal firms up, even over a few days the shoes will finally settle into place. Otherwise it sounds like a bleeding problem.
-dk
