Brake Light
Discussion in '80-Series Tech' started by davidfj406080, Apr 17, 2003.
  1. davidfj406080
    davidfj406080
    193
    1
    Apr 6, 2003
    Albuquerque, NM
    :-/ On my '96 FZJ80, the brake light illuminates evry faintly sometimes, easier to notice at night. It does not seem to be the fluid level. Then if you pull on the E-brake it will light up bright. Sound familiar? Does it mean anything?Thanks-
  2. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Somewhere in the foothills...
    David,
    It might be the sensor in the master cylinder cap. Unplug it and see if the brake light goes off.  Another symptom would be that the cruise control may not work when the brake light is dimly lit.
    The fix is to inspect the resevoir cap if unplugging causes the light to remain off and replace if you can't find a problem.
    -B-
  3. Underdog
    Underdog
    57
    1
    Mar 28, 2003
    If it is the light for the parking brake then maybe it is the parking brake on/off switch. My light comes on occasionally when it feels like it and goes off when I jiggle the brake handle. When I get a chance I'll see if the switch is loose or maybe needs to be replaced.
    If I'm way out in left field then just disregard!
  4. landtank
    landtank SILVER Star
    18,425
    601
    Mar 27, 2003
    Groveland MA
    No UnderDog your not way off. There is only two switches in that circuit, the e-brake handle and the fluid level. Unplugging one at a time should reveil the culprit. But from past posts it's usually the fluid level switch.
    Rick
  5. davidfj406080
    davidfj406080
    193
    1
    Apr 6, 2003
    Albuquerque, NM
    ;) THANKS, GUYS, i'LL TROUBLESHOOT IT AS SOON AS I GET A MINUTE TO CATCH UP!! sorry for shouting! It's weird, the light is so faint that unless it is at night it is not noticeable, switches are either on or off, not variable resistance or whatever so they get brighter- I thought it could be stray light from a nearby switchlight, I'm used to the older Cruisers...
  6. Lordulthan
    Lordulthan
    5
    Jan 22, 2007
    San Francisco
    Wow...I just logged on because I have the exact same problem.... at first i thought that it was my fluid level getting too low... but now that i have this new found advice... i'm gonna give it a shot. Because I'm a specfic guy... can we do this step by step? I unplug the brake fluid sensor... if thats the culprit it WILL go off? If not, then it might be the brake handle sensor?
  7. CJF
    CJF
    6,901
    359
    May 31, 2005
    1) Make sure the brake fluid's not low.
    2) Unplug the sensor. If the light goes out (almost guaranteed it will), then yes, that's the problem.
    3) Clearly you did search, but still, we've done this about once a week lately... ah well...
    4) Welcome. :)
    Curtis
