Brake Light Fuse Blowing
Discussion in '80-Series Tech' started by Gray Rider, Apr 29, 2012.
  1. Gray Rider
    Gray Rider SILVER Star
    647
    13
    May 17, 2011
    NC
    '96 Eighty
    My brake light 10 amp fuse will not hold.
    Removed portion of after market trailer harness.
    (will remove the remainder as soon as possible)
    The fuse block slot where the 10 amp fuse inserts is visibly burned on the power (battery) side of the fuse slot but not the load side.
    Anyone have any thoughts as to whether this makes the problem worse?
    Thanks!
  2. Offroads4x4
    Offroads4x4
    1,427
    Media:
    8
    22
    Dec 16, 2009
    SLC, UTAH
    No question you have a short. Yes you need to clean the burt area the best you can. Be sure to always use dielectric grease on all you electrical connections to help your connections continuity and keep it from burning/blueing.
    Start by looking for the obvious like you've done on the trailer light wires. Next check your hatch wires for the third brake wires.
    Then check each tail light socket and replace each bulb. I've seen cheep ones short out. Checking the wire looms for the rear lights paying close attention to the area where the wires go through the body.
    Then report back.
  3. scrowley
    scrowley
    3,152
    326
    Dec 13, 2008
    N. West CT.
    This happened to me and it drove me crazy!!!! It was a dead short......and it ended up being a wire on the aftermarket radio that was not used and not capped or taped but just cut off flush was touching something in the dash causing the short. Before I figured this out I checked all lights and light sockets in that circuit. Checked all wires for towing harness. Have you installed a aftermarket radio lately??
  4. nuclearlemon
    nuclearlemon not an addict Moderator
    15,579
    Media:
    87
    398
    Jan 30, 2003
    meh-ico, colorado
    for anyone who finds wires like this, just grab a butt connector and crimp it on the one end and leave the other end open. easy way to leave it open for something in the future and keep from shorts like this. if it's in an area where you're concerned about water/dirt getting in, you can put a vacuum cap on there (or skip the but connector and use a piece of heat shrink). also, please don't be a p.o. and use checker auto butt connectors, use a quality heat and seal style connector ;)
  5. Gray Rider
    647
    13
    May 17, 2011
    NC
    Will do Off Roads, Thanks
  6. Gray Rider
    647
    13
    May 17, 2011
    NC
    No radio replacement. Probably rule that one out....
  7. 86tuning
    86tuning
    2,572
    12
    Dec 9, 2007
    Vancouver BC
    quick and easy diagnostic tool is to make a test light using a 12v bulb and a couple wires. plug these wires into the fuse socket, then start unplugging stuff until the lamp goes out.
    first thing I would check is the tail lamp and brake lamp bulbs. next would be the trailer wires.
    good luck!
  8. Gray Rider
    647
    13
    May 17, 2011
    NC
    Hey 86tuning
    I am going to check out the brake lamps and trailer harness real close. But if I use the temporary test light that you a suggesting, won't that act as a "straight wired non fuse " situation ?
    Thanks
  9. wesayso
    wesayso
    253
    4
    Sep 3, 2008
    hampton, VA
    When this happened to me it was the trailer lights module that was bad. Replaced it and everything was cool. Replaced the module with this.
  10. Gray Rider
    647
    13
    May 17, 2011
    NC
    Update - before the fuse blows I'm pulling 14 mAmps on the 10 mAmp protected circuit. So still got a short somewhere. Removed trailers harnesses.....
  11. Gray Rider
    647
    13
    May 17, 2011
    NC
    Here's the wrap up for now:
    1) Removed 2 after market trailer harnesses.
    2) Got the fuse to quit blowing by bending each tab of the 10 mAmp fuse in opposite directions for secure insertion.
    3) Still drawing 14 mAmps on the circuit but the 10 mAmp fuse is holding. Must still be a stray ground somewhere, good , bad or evil...
    Weird thing is: the fuse "holder" on the fuse block is a bit smoldered from the earlier melted fuse. I understand that this causes higher resistance and therefore ups the current amps at that point. But the 10 mAmp is holding.............
    I guess I will go worry about something else.....
  12. 86tuning
    86tuning
    2,572
    12
    Dec 9, 2007
    Vancouver BC
    Nope.
    What happens is your 12v bulb is the 'load' and will light up brightly until you find and remove the short circuit.
    Once you unplug the cause of the short, the bulb will go out.
    There will be no damage to anything unless you manage to mangle up the fuse socket, or allow the bulb to melt carpet or similar.
    I use a turn signal/reverse bulb 1156 with pigtails soldered to it. 18g stranded wire can be carfully plugged into the fuse socket. Or if you have some spare toyota connectors laying around, you can un-pin them from the plug and use those. I've cut faulty 02 sensor plugs off and used those terminals. they work great.
    hope that helps. You'll find it. Most likely culprit is the trailer connector, or melted tail lamp bulbs causing a short.
    Good luck!
  13. Gray Rider
    647
    13
    May 17, 2011
    NC
    Ok 86 - will keep this deal open and chase the culprit and report back
    Thanks!
  14. Scamper
    Scamper
    1,460
    2
    Mar 28, 2003
    Somewhere in NJ
    When you removed the two (?) harnesses, did you find a wire going up into the tail light? If the PO had a trailer with surge brakes, he may have wired the reverse light to his surge brake wire and this may be loose or shorting on something.
  15. Gray Rider
    647
    13
    May 17, 2011
    NC
    Hey Scamper
    Yes the right tail light has a t connector with no wire protruding on two of the wires inside the lens. Still chasing.....
  16. Offroads4x4
    Offroads4x4
    1,427
    Media:
    8
    22
    Dec 16, 2009
    SLC, UTAH
    Have you checked under the dash at the brake light switch on the brake peddle? Most of the time people jump one of the switch wires for the trailer brake/surge brakes.
  17. Gray Rider
    647
    13
    May 17, 2011
    NC
    Hey Offroads,
    Good point, I did checkunder the brake peddle, but not necessarily for additional wires......still chasing.
    Thanks!
  18. Offroads4x4
    Offroads4x4
    1,427
    Media:
    8
    22
    Dec 16, 2009
    SLC, UTAH
    Try unplugging the left tail light and see if it still blows, then try the right one to eliminate your sockets and the socket wires.
  19. Gray Rider
    647
    13
    May 17, 2011
    NC
    Well now the circuit is not blowing. If is just continuing to carry 14 mA on the 10 mA fuse....
