Brake guide pin lube?
Discussion in '100-Series Cruisers' started by scottm, Jul 7, 2011.
  1. scottm
    scottm
    3,082
    Media:
    8
    614
    Mar 27, 2003
    Third Coast, USA
    I've always used high-temp moly grease for brake guide pins, after trying things like anti-seize. I just did my rear brake pads, and the guide pins seemed to have rubber dampers and a clear lube. Everything was in excellent shape, so I put it back together without adding lube.
    This looked like dielectric grease (silicone grease), which I use for a lot of things with rubber seals. It's good to 400*F, I'm thinking this is the stuff. Googling around, silicone grease seems to be the proper lube for brakes, I'm planning to use it for my front brakes.
    Anyone heard any different?
  2. OregonLC
    OregonLC Brown Thunder Roles
    4,685
    Media:
    9
    591
    Jul 20, 2010
    Portland, OR
    I just did the rears on my friends 03 and his pins were dry, to the point that the inside pad (piston side) was gone while there was ample life left in the outer. We just used Napa Sil-Glyde (what the parts guy recommended).
    It is a bugger to get the boots off and back on. Removing the outer shield with the 2 little 8mm bolts makes getting to the boots much easier.
  3. scottm
    scottm
    3,082
    Media:
    8
    614
    Mar 27, 2003
    Third Coast, USA
    Hmm, my boots came off easily, not as snug as I'd like. Probably ten-cent parts if I'd thought to add them when I ordered from cDan.
    I bent the shield up just a little to get a socket on the guide pin bolts, maybe that helped.
  4. beno
    beno 04111-61046: I have the last one. Supporting Vendor Moderator
    19,520
    Media:
    382
    7,425
    Aug 28, 2004
    Covington, GA
    I've got a tub of brake caliper grease that I use on all things brake caliper related. Any auto parts store should have it.
  5. super90
    super90
    1,005
    Media:
    25
    28
    Apr 16, 2005
    TEXAS !!!
    That's good stuff. Been using it for a while on various vehicles.
  6. OregonLC
    4,685
    Media:
    9
    591
    Jul 20, 2010
    Portland, OR
    I should rephrase - bugger to get back on. off is the easy part!
