Ok, Im freaking confused. Specs, 85 cruiser, 91 runner booster (no check valve), 350 ramjet V8.
So ever since I got the 60 Ive had no brake boost with the engine off. I installed a 91 4runner booster last summer when mine went that did nothing to solve the no boost without engine running problem. The runner has a check valve on the firewall and it is not part of the booster so didnt really expect it to.
Heres part one of the question. I cant really get my head around how the whole thing works. I know the engine sucks thereby providing boost for the brakes. With the engine sucking how is a check valve supposed to do anything to keep some vacum in the booster when the engine is shut down? I might be looking at it the wrong way but to me the only way a check valve would work in this situation is if the engine were blowing into the booster and the check valve closed to keep it pressurized after the engine is no longer running.
Part two of the question is this. I ordered a couple different check valves (1 psi to open, good to 125 psi) and both dont seem to provide enough air flow to the booster. With the motor running and vacum line disco'd there is some serious sucking going on. Throw on the check valve and that sucking is seriously restricted. Anyone know what the set up is on a chevy/gm 5.7L booster? Is the check valve part of the booster or is it remote/in line? Im thinking a check valve from the chets would have more flow and resolve my issues.
Any insight would be appreciated. Maybe Im just dense...
D
D
