Body lift
Discussion in '40- & 55-Series Tech' started by kc_chevota, Feb 19, 2003.
  1. kc_chevota
    kc_chevota SILVER Star
    1,180
    74
    Feb 19, 2003
    Kansas city MO
    Hi im new to the forum but have been an owner since 86 when my dad gave me my 79 fj40 he baught new.  I have seen some posts stating they had body lifts. who makes them or did you custom make them yourselves? if so how? "btw" im at the start of a frame up rebuild
  2. Mavric1298
    Mavric1298
    163
    Oct 28, 2002
    IMO i dont like body lifts, their cheap, but they have a number of downfalls. If your looking for 2-4", then just go with a spring lift.
  3. woody
    woody Internet Fireman Staff Member
    10,335
    Media:
    303
    1,094
    Jan 15, 2002
    Toquerville UT
    Custom, from poly boat rollers.
    IMO, any body lift over 1" on a FJ40 looks stupid, but that's just me.
  4. Niner
    Niner
    821
    Jun 4, 2002
    Readfield, WI
    Hockey pucks are what was used on mine their 1" thick, just drill a hole in the center
  5. Gumby
    Gumby Supamod Staff Member s-Moderator
    11,781
    310
    Dec 13, 2002
    Knee deep in hookers and gin
    I have a 2 1/2 inch body lift on mine. To make it look right it's a lot of work. My tub is extended behind the wheel wells to meet the bumper. Every place the tub touched the frame has a 2 1/2-.125 square tube body mount. The brakes and wiring were all built from scratch and the steering was all done after the body was done so no additional work was needed there for me. The shifter levers needed to be adjusted. The bib is still not right, but I hope to fix that when I cut off the frame rails after the coil conversion and build a stinger front end. :D
    There are many advantages to a body lift. Low CG, less body trimming, tire clearance without increasing the drivetrain angle, etc. It is not a cheap alternative to doing a good suspension lift unless you want it to perform poorly, not last and look bad.
    I didn't go with the boat rollers because I felt the steel was stronger and less prone to flex and sheet metal work hardening. Hockey pucks may work in warmer climes, but I have heard many stories of them breaking up and spitting out over time.
    May not be true. The plural of anectdote is not data.
    Not the first time I've been accused of looking stupid. Where's that <flipoff> icon? ;)
  6. woody
    10,335
    Media:
    303
    1,094
    Jan 15, 2002
    Toquerville UT
    Gumby, your trips to the plastic surgeon don't count as body lifts... :flipoff2: lol
  7. Medusa
    Medusa
    416
    1
    Jun 17, 2002
    Sometimes a 1-1.5" body lift is useful in placing the drivetrain in a desired position or allowing clearance for that Atlas transfer case. When that is the goal, a small body lift is fine, but I wouldn't rely on the approach just for "lift"
  8. kc_chevota
    1,180
    74
    Feb 19, 2003
    Kansas city MO
    thanks hocky pucks good idea. im only thinking of an inch or so in combination with a soa
  9. Slowerthanu
    Slowerthanu SILVER Star
    1,326
    8
    Apr 23, 2002
    Bountiful, Utah
    I have a 1 inch body lift, I did it so I could eventually lift the engine and make a flat bottom. Plus I didnt have to lower my bumpstops as much, hence more travel.
    I believe a 1inch body lift is the maximum an FJ-40 should ever see.
    I used aluminum stock cut to 1 inch thick and drilled holes in them. The bolts were an absolute B***h with my aluminum tub, had to find all stainless bolts.
