- Thread starter
- #741
I typed that on my phone and it was meant to read o-ring, lol. I've been able to compress them in once cooled down.
Lol, I just assumed that I had the name wrong...wouldn't be the first timeI typed that on my phone and it was meant to read o-ring, lol. I've been able to compress them in once cooled down.
Anyone have any issues with the o-ring / gasket getting stretched during this process? I can only think that it happened when I separated the two sides to drain. I haven't touched it until I went to put it back together and now it is way too big. Is it safe to assume that this is not replaceable?
I have some "Right Stuff" Gasket maker, would this work as an alternative?
See pic below for pic
Best,
Smitty
O-ring get larger happened to me too. I put it back on groove and slowly stroked until it shrank.
Just my 2c
I just replaced the oil with 20k and didn't adjust mine and it helped quite a bit. On a 114 degree day in high the temps only got up to 205 with the ac on and on a dirt road. So under 20 mph. I'll be taking it in the washes to really test it this weekendWow that's a ton of reading! I got through a portion of it and will keep reading, but is it necessary to mod the blue clutch? Any of you just bolting it up out of the box and seeing improvements over the stock clutch?
I didn't clean it with anything. The only thing that I can think of is when I pryed the two halves apart if the sudden breaking of the seal stretched the o ring. That is the only thing I can come up with.
Smitty
Best,
Smitty
Smitty, IIRC it's normal for that gasket to do that. What helped me was to put the gasket in the freezer or fridge for a couple of hours. It will contract and you can pop it into place easier. Landtank's advice works well, also. Just don't try to force with sharp or hard tools as you may damage it.
