- Thread starter
- #121
I'm pretty familiar with 230's (check the link in my signature ), I've never been a fan of the individual factory shifter.
Just put a doubler in my 62 and built a set of triple shifters, I would love to have them all be air-operated as I want ARB's in the future and could link the systems. Plus I've found it pretty hard to make shifter linkages that aren't clunky/sloppy.
I thought about air shfting the high-low lever, but I didn't want to use a dual action air ram. The control system for that gets a little complex in my opinion. I don't mind air actuating things, but I think they should default to one position, or the other, if the air system goes down. On what I am building, I am defaulting to open with the center diff using the spring bias in a single action cylinder. That way if the air system fails it will just open the diff. I would like to be able to access that area of the linkage with a small panel on the tunnel as backup. I run an ox-locker with a small air actuator built into the diff cover on my old Willys jeep. It has been a very reliable and simple system for me. I hope I can duplicate that reliability in this center diff locking mechanism...and the Toyota E-lockers in the near future.
I think I have a pretty good plan for the high-low lever linkage to eliminate slop and rattles. I am building a double shear bracket off the transmission for the pivot point of the shift lever. I am going to build the pivot to use a shoulder bolt pin and some self-oiling bushings pressed into a small housing made from some DOM tubing. I should be able to adjust the tension on that assembly pretty easy with an all metal lock nut on the shoulder bolt threads. The linkage rod will all be small ball joints with rubber shields. I think it should be pretty decent when it is all done. Building out the detail stuff always takes the most time.
