1980 BJ40 in Costa Rica. Front disc brake conversion by previous owner. What the heck is this hose coming off the rear brake line splitter? It appears to be just a piece of braided rubber hose about a foot long, held upright by a tie wrap with a solid plug clamped in the end. It looks somewhat factory original. What does it do? I have not seen it on any parts drawing or in any service manual. Could it have anything to do with me not being able to get the air bled out of the right rear (last in the chain / farthest from the master). I tried vacuum bleeding and suspected air was being pulled in around the bleeder threads. I sucked two bottles of fluid through, the fluid was clean but still lots of air - big bubbles. Today I used the two man method with an assistant, pushing a full bottle through with the same results - still lots of air. If air is leaking INTO the system, why is fluid NOT leaking out somewhere. Where is the air getting in? I have pulled all wheels and drums and inspected wheel cylinders and front caliper pistons. No fluid leaks. Moving on up the chain, both front brakes and the left rear (1st, 2nd and 3rd in line from the MC) bled successfully, no bubbles. The other problem is the brake pedal goes to the floor the first time you push gently. But if you stomp it hard or pump it up, the pedal is hard and holds / does not leak down. I installed a new master cylinder even though the old one wasn't leaking out the back seal. It didn't seem to make a difference. I guess it wouldn't be the first time someone got a new master cylinder that was bad. I bench bled the new MC, and bled it again when connecting the lines, then bled the wheels starting with the farthest from the MC (RR on mine). I never let the reservoir get low. Having the motor running doesn't seem to make any difference and the booster is getting and holding plenty of vacuum. I tried to rule out rear brake adjustment by expanding the shoes all the way out until the wheels were locked. Still have to pump the brakes up. I may be dealing with multiple unrelated issues. I am stumped.
