Birfield Click?
Discussion in '80-Series Tech' started by Hltoppr, Aug 4, 2003.
  1. Hltoppr
    Hltoppr SILVER Star
    2,024
    Media:
    4
    5
    Aug 29, 2002
    Port of Indecision...otherwise Northern Arizona
    OK ya'll quick question for your opinions...
    Going uphill (15+ Degrees) off road I get an occasionsal high pitched clicking which seems to come from the front end. It's not the "popping" sound that normal birfield wear indicates. Could this still be a birf?
    -H- ???
  2. landtoy80
    landtoy80
    5,668
    241
    Mar 13, 2003
    North Front Range, CO
    I get a bird like tweet when driving on a road with bumps. It is front and rear. I have had that noise on the toyo mini too. Does it make that noise with the brakes on? My guess it the brake pads move and make a tweet. I don't have the anti squeel shims on my pads.
    kurt
  3. Hltoppr
    Hltoppr SILVER Star
    2,024
    Media:
    4
    5
    Aug 29, 2002
    Nope, no brakes involved, and it's definitely not clicking pads... almost sounds like some small splined something is spinning. ???
    -H-
  4. shocker
    shocker
    1,185
    1
    Apr 10, 2003
    Kansas City, MO
    Just one more "make sure it's not the brakes"
    When I did my birf job a few months back, I saw that my front calipers needed a rebuild. Couple of my pads were wearing at a slant. Went ahead and put everything back together, but may have not put the pads back exactly where they came from. Over the next few weeks (before I put on rebuilt calipers and new pads), I'd get a high-pitched clicking sound when I'd turn. I knew it wasn't the birfs because the sound was obviously not coming from something immersed in grease. Knew it was the brakes because when I'd hear the sound while turning, it would go away if I hit the brakes soft enough to just get the calipers to compress the pads to the rotors, not hard enough to stop.
    After I replaced the calipers and pads, silence. Well, that is except for the screaming moron behind the wheel. ;)
  5. BMT
    BMT
    325
    Apr 1, 2003
    O.K. A couple of goofy questions. Was the center diff locked? At what speed was the noise (e.g. tire rotation, drive shaft rotation)? It's the front drive shaft that is new right, are the u-joints greased well?
  6. Hltoppr
    Hltoppr SILVER Star
    2,024
    Media:
    4
    5
    Aug 29, 2002
    Low range, slow speed (under 5mph) center diff was locked. I just greased the u-joints before the trip...
  7. upcruiser
    upcruiser
    334
    Mar 28, 2003
    Marquette, MI; Jackson, WY
    It was probably your teeth chattering as you were descending Black Bear ;)
    Heh, heh, I'm getting the pictures developed as we speak, I'll post them soon.
