Has anyone looked into utilizing the readily available electronics from a Ford dual tank truck to handle the switching from one tank to the other?
It consists of two tanks with a sending unit/fuel pump in each tank, electrical switch to swap power/signal from one to the other and a mechanical selector valve that will block off the return line to the opposing tank when fuel is sent through it from the other.
Here's an electrical diagram the dual tank setup:
Some adaptation is required but at least all the parts can be pulled off trucks plentiful in US junkyards.
