Best way to paint aluminum ??
Discussion in 'Paint and Body' started by MANUCHAO, Jun 13, 2012.
  1. MANUCHAO
    MANUCHAO omnea mea mecum porto SILVER Star
    4,238
    Media:
    266
    695
    Nov 8, 2004
    Sur Cal
    I got a couple of aluminum drawers that Im going to use for my drawer system.
    What is the best way to treat them. I want to paint them a white color on the inside and keep the natural color of aluminum on the outside..
    Do I prime the inside first and then paint them?
    HomeDepot has a aluminum specific primer/paint (rustoleum brand) should I go with that ?
    Can I use a clear coat for the outside and call it good ?
    The inside will also have a clear (almost see through) rubber mat on the bottom to dampen any clanking....
    Any input on this is most welcome
  2. MANUCHAO
    4,238
    Media:
    266
    695
    Nov 8, 2004
    Sur Cal
    Asking around I was told to clean the aluminum really good and let it dry for a few days.. then score it and clean it again with Acetone and use this primer first
    RustOleum.com
    then use this, once the primer dry and cure for two days....
    RustOleum.com
    Finish came out great !!!
    Now time will tell if I did it right and/or if picked the right product.....
  3. LRChops
    LRChops
    173
    Media:
    7
    Jul 8, 2011
    Auburn CA
    Consider having them Anodized.
  4. MANUCHAO
    4,238
    Media:
    266
    695
    Nov 8, 2004
    Sur Cal
    I did but I was press for time then.. and I didn't know how much anodizing them would run for....
    Thanks for the input...
  5. Dynosoar
    Dynosoar Slightly Disturbed SILVER Star
    3,531
    196
    Feb 4, 2006
    SoCal
    You need to use a good self etching primer. The paint will stick well to it then.
    Dyno
  6. reevesci
    reevesci Enabler Supporting Vendor
    10,821
    Media:
    1,678
    6,605
    Jun 21, 2011
    BACK IN THE SHOP!
    X2^^ I know guys that have scuffed up the aluminum and used epoxy primer and had good long term results.
    GL
    J
