Best way (easiest) to remove freeze plugs
Discussion in '40- & 55-Series Tech' started by thecrazygreek, Jan 16, 2007.
  1. thecrazygreek
    thecrazygreek SILVER Star
    2,903
    Media:
    6
    286
    Sep 26, 2005
    Oregon
    Just need to know how it's done... yes I searched...
    Thanks
    :cheers:
  2. fj40forlife
    fj40forlife
    1,531
    Dec 18, 2005
    Orange County
    a hammer and prybar =]
  3. Jake40
    Jake40
    85
    1
    Jul 13, 2003
    Fort Worth, Tx/Brisbane, Au
    get a hammer and a screwdriver and hit it off center to turn is sideways, then just pull it out with some pliers
  4. FJ40Jim
    FJ40Jim The Cruiser Whisperer
    9,244
    982
    Sep 26, 2003
    Lancaster, Ohio, USA
    Easiest?
    Drain all the coolant.
    Replace w/ water.
    Park outside on a cold night.
    Viola! Core plugs all popped out! :)
    Disclaimer: Just kidding. This technique will likely crack a block.
  5. wckgitcrazy
    wckgitcrazy
    86
    Apr 8, 2006
    Get a dend puller, screw it into the plug and bang it out. Don't have one then the screw driver/prybar/hammer method works great. The freezing water also works but don't go there or you will be posting here looking for info on someone to weld your block.
  6. Leaping Deer
    Leaping Deer
    4,559
    Media:
    9
    65
    Dec 15, 2005
    Whitinsville, MA
    Yep... Slide hammer should work
  7. ducktapeguy
    ducktapeguy
    735
    38
    Jan 6, 2003
    Aren't the purpose of freeze plugs to prevent a cracked block in case of freezing temperatures? Or do they not work right? You can tell I'm from California, never had to worry about freezing temperature (until last week)
  8. wckgitcrazy
    wckgitcrazy
    86
    Apr 8, 2006
    Yes in a perfect world, I have only had one pop in 30 years of vehicle ownership. The idea being that as antifreeze freezes, figure that out, it will expand and push out the freeze plug. Now that being said if the plug goes and all the slush follows no prob. but if there is sufficient liquid left and it all freezes and expands it could take the path of least resistance. If that is a thin wall of your block, so be it. My thoughts, could be wrong.
  9. FJ40Jim
    9,244
    982
    Sep 26, 2003
    No, the core plugs are in the casting to allow breaking up and removing the sand cores for the casting mold.
    They have the happy benefit of allowing frozen water to expand and push out the plugs (sometimes). But that does not always work. Depending on the shape of the water jacket, there can be pockets of water that do not have easy access to a plug, or a large enough plug. Then the expanding ice will just crack the block or head through a core plug opening (a natural weak spot).:eek:
