Best tool for removing surface rust?
Discussion in '60-Series Wagons' started by FlowState, Apr 24, 2011.
  1. FlowState
    FlowState
    106
    Mar 28, 2011
    San Marcos, TX
    I'm anxiously awaiting the trip to go get my new baby (1984 60) and want to make sure that I have the tools needed to do the job. I bought an angle grinder with cutting disks as well as flexible grinding disks, and that will do just fine for most of the work.
    What I'm wondering about is tiny polka-dots of rust I will have on the surface of otherwise clean, straight panels. I'm a little worried that an angle grinder would be prone to tear into the metal too much.
    Should I be fine with the angle grinder and flexible grinding disks, or is there another approach (like an orbital sander) that might be gentler?
    EDIT: I guess I'll ask the rest of my questions here:
    Once I've removed rust (surface or slightly pitted), what is the best thing to spray over the top to prevent further rusting? I'm going to be leaving the primer (or whatever y'all suggest) on for a while, as I'm waiting to do my paint work until after the mechanical stuff is how I want it.
    Thanks,
    ~Eric
  2. NQCruiser
    NQCruiser
    351
    104
    Nov 23, 2008
    Gowrie Junction, Queensland, Australia.
    Probably depends a bit on how bad and where it is, but I generally use a 4in angle grinder and a Twist Knot Cup Brush or similar style wire wheel. You can use it light to just take the surface layer off, or push down hard to really strip that paint back and dig at the metal. I've found these to be a bit gentler than some of the flap style discs, although these leave a smoother finish if you use a fine enough grade.
  3. FlowState
    FlowState
    106
    Mar 28, 2011
    San Marcos, TX
    What I'm really worried about is messing up the metal. If the rust is half an inch wide, and I end up stripping enough paint that I need 3 inches of primer, that's fine, as long as the metal won't be roughed up.
    I don't mind buying multiple discs, but I'm definitely worried about the finish. In that case, what discs would you use? Again, I don't mind using as many as I have to to kill the rust but leave a smooth finish.
    Thanks heaps for the advice, mate!
  4. Eldorado556
    Eldorado556
    302
    2
    Jan 15, 2011
    Westminster, CO
    Pick up one of those discs made for paint and rust removal. Gator Grit and Norton make them. I've been using them to remove rust from an old bull bar. Works quickly and doesn't snag like a wire wheel.
  5. FlowState
    FlowState
    106
    Mar 28, 2011
    San Marcos, TX
    I found a 3m quick-switch adapter and paint/rust removal discs for the angle-grinder. Based on the reviews, it looks like this is enough to strip surface rust and feather the paint.
    The first part of my buildup thread is going to be rust removal, so I'll do full reviews on these.
    Thanks again guys, helped me sort it all out.
    Eric
  6. 62LostInMn
    62LostInMn
    312
    20
    Jul 5, 2009
    Minneapolis
    If you have a decent corded, variable speed drill you can get some small abrasive disc tools and wire wheels that will fit the drill. I like these for smaller detail work. The angle grinder is a bit of a beast and tough to control for some locations.
    Jim
  7. scrowley
    scrowley
    3,152
    328
    Dec 13, 2008
    N. West CT.
    I have to say I have done this a lot and what works for me...
    I start off sanding the surface rust with a red cookie. The air tool that accepts cookit discs. It also holds wire wheels which are great for the frame cleanup. The cookies are great because they dont hurt the metal at all. The cookies come in red (most abrasive) green (middle) blue (least). If all rust is gone in your concern area use a rust prevent primer of your choice. For an undercoat primer these are all about the same. If your not going to paint for awhile and live in a high rust area you might want to use some SEM rust shield or por 15 for now then resand when you do paint it. Good luck. hope this helps
  8. FlowState
    FlowState
    106
    Mar 28, 2011
    San Marcos, TX
    I'm in Texas, so there's no worries on new rust. I'm gonna go with the angle grinder, since I'm going to be doing frame stuff, and some cutting.
    I am pretty sure from your description that the abrasive discs that I was talking about earlier are the same ones that you're referring to. As far as the rust-preventative primer goes, that's likely what I'm going to do... likely in that nice, boxcar red, so I am constantly reminded that I need to get the paint done :D
    Like I said, I'll do a writeup as the first part of my buildup. One hopes I do this right after asking all these questions.
  9. daveIT
    daveIT
    729
    Mar 25, 2009
    Colorado Springs
    Bumpers
    How about clearing the surface rust from these bumpers? What can I paint/refinish them in to prevent this in the future? I don't have a grinder or anything like that.
  10. Lost
    Lost
    1,330
    Media:
    7
    3
    Oct 24, 2007
    geographical area known as canada, near ontario
    get a welder. rust will come back eventually even if its 10 years later.
    then again why buy a rusty rig?? hope you got a good deal.. and furthermore, id save your money for any possible mechanical problems before you dive into cosmetics...
  11. ff347
    ff347
    787
    Media:
    3
    51
    Nov 16, 2004
    Simpsonville,SC
    3M US: Roloc Bristle Disc
    They look silly but they work great on everything I have tried them on. Sharp edges kill them in a hurry.
  12. FlowState
    FlowState
    106
    Mar 28, 2011
    San Marcos, TX
    I did get a good deal. And like I said, there's just some surface rust, only cancer in one spot on the right quarter panel wheel well. Mechanically, the truck is immaculate. Worst case scenario, I've got maybe 500 dollars worth of body stuff, including parts.
  13. GLTHFJ60
    GLTHFJ60 Rum Runnin' SILVER Star
    19,286
    2,795
    Apr 18, 2005
    Durham, NC
    For thick metal, use a knurled wire brush. It'll strip everything down right to the metal in no time. For thin metal, I've always used the 3M paint eater drill tools. They're a porous composite that fits onto a drill and strips paint ( rust as well ) with ease.
  14. laguna80
    laguna80
    1,158
    1
    Sep 27, 2006
    HI
  15. FlowState
    FlowState
    106
    Mar 28, 2011
    San Marcos, TX
    out of curiosity, Laguna... I just looked those up and didn't see different grits. Like I said, I am really concerned about the finish... what do you follow these up with?
  16. TobyB
    TobyB
    1,275
    31
    Jan 18, 2011
    Seattle
    the 3m/norton/etc abrasive stripping pads leave a good finish for filler-
    either sprayed or spread, and they remove a minimum of metal.
    you can get them anywhere (hd, blowes,etc).
    the industrial ones are often cheaper, but harder to find.
    i then etch prime, seal, fill (high build spray often works for little rust spiders) and finish...
    hth,
    t
