Hey man thats cool!!!! I have mine where it will hit my right knee. Oh will... the ashtray looks like a great place to put things......I will work on it next.
The Widmer brewery is 20 minutes from my house. They have a nice pub across the street from their brewery that serves most of their beer... on tap.. Good sausage too.
Looks like a fun place. That beer looks tasty! I don't think they would ship me a case
best location is where it's easy for you to hit it in a panic stop.
Crap, there goes the right knee....!
More info on the removable controller? Although I suspect it won't be too difficult to make my Prodigy removable between vehicles.
Nice install...
Alas I have a CB in the ashtray so I installed my controller just to the left of the console, above the skinny pedal about the location you show in your second picture only lower on the flat part of the panel. Despite what I thought originally I have NEVER hit it with my foot or leg, yet
Did you find the most challenging part of the entire installation was splicing into the brake switch wire? Very little room to manuever up there, short piece of wire, etc...What a total PITA and it was obvious Toyota did not design the FZJ80/LX450 with a trailer brake in mind as CDan has stated before...
I haven't wired/spliced anything yet. I wanted to get the 7 pin mounted first so I have something to wire to.
Now I'm all set and can start the wiring tomorrow. That reminds me, I still need to buy wire.
Oh, well good luck then ...If you aren't sure where the brake switch is the FSM shows it. If you don't have a FSM then follow the brake pedal "lever" up behind the dash and push on the brake and watch the "action" of the lever and you should see the switch way up in there. The wire you splice into is on the side of the switch facing the dash (which will probably be obvious). Just not much to work with. IIRC I actually popped the connect off the switch to get a fighting chance at it. IIRC as well taking off the lower trim piece didn't help to get to the wire.
I will also be interested to see, after you get everything wired up if you have parking/running lights on your trailer. I installed a brake controller and the Hoppy 7-pin adapter back in April. My LX already had a 4-pin connector that I plugged into the Hoppy. All my lights work except for the parking/running lights which means I cannot trailer at night. I've wondered if it is because my existing 4-pin plug has a ground wire on it but the 4-pin on the Hoppy adapter doesn't have a ground on the 4-pin part, just an overall ground wire (big white one with the ring terminal)
Hoppy says it shouldn't matter but...
P.S. You need to tell Widmer brewery to offer their beer out of state! Nothing better than a good Hefeweizen, especially if you're actually enjoying one in Germany with some Schnitzel
Almost forgot, this one is for GreatLakes.
Heres a coulple to make you drool. I was contracted to design and buile these brush guards for a local trailer company. Never done before. This unit is on the show circuit now. Will be in Vegas next week. Looks like it would fit yours. What do ya think?
