Best Grease Gun Ever Contest
Discussion in 'Workshop and Home Improvement' started by rsbcruiser, Oct 6, 2007.
  1. rsbcruiser
    rsbcruiser SILVER Star
    1,459
    Media:
    1
    5
    Aug 4, 2007
    Portland, Oregon
    With 16 grease zerks stock from the factory the FJs' need a quality grease gun. The demand becomes even more apparent with the addition of aftermarket gear such as greasable shackles and greasable door hinges (what you say, door hinges?). My 74 FJ-55 is heading for a total of 26 Zerks. With that many or more possible, the best tool for the job becomes a serious matter warranting deep thought and disscusion. So here it is, a forum to iron out this issue. Please submit a picture along with a brief description telling us why you think your grease gun is the best. To kick it off I throw in my old timey Allstate. It has the classic good looks of a standard along with a flex hose and low clearance head to fit those hard to reach nipples. Ok, I just had to get head and nipple into the same sentence. I myself vote for the OEM Toyota grease gun. (n2666s) showed me his! Come on lets see it again N2666s. Trollhole bite this one fish on! Gotta see that much ballyhooed Lincoln. Community vote wins it. Prize? maybe a couple greasable hinge pins, I don't know, Forget it guys, not giving away the beasty no way! Get that evil thought out of your curmudginy heads right now!
  2. Cruisertime
    Cruisertime
    461
    Media:
    20
    11
    May 14, 2006
    Maryland
    Dont have a pic of mine handy right now. Heres a link, http://www.tylertool.com/lincoln.html
    Works great on heavy equipment, esp when you have to adjust tension in tracked vehicles. If you are stuck in a position that isnt muscle motor friendly its a breeze to use. I work with a lot of fittings so the price was worth it. I did have an aip powered one, didnt work if compressor wasnt working. Had OBA just going thru that many cycles was and not being able to use impact at same time was annoying.
  3. 71FJ40
    71FJ40 SILVER Star
    793
    10
    Jan 19, 2004
    Colorado Mountains
    Tried lots of different brands and styles - got sick and tied of broken or unpurgable guns
    After some research came across Alemite - wish I had found them years ago...
    Alemite
    Easy to load
    Very easy to purge air
    Excellent Quality pump
    This is the only grease gun I have ever used where loading of cartridges is clean and easy. The cartridge holder on this gun is actually several inches longer than the cartridge thereby allowing the spring/plunger assembly to compress completely out of the way and easy installation of
    a new cartridge
    http://www.alemite.com/catalog/details.aspx?identifier=guns_professional
  4. Pin_Head
    Pin_Head
    13,673
    1,242
    Feb 6, 2002
    OC, CA
    The best has to be the full pneumatic gun on the retractable hose reel. With the needle point installed, I could hit the service manager on the back of the neck from across the shop and just say "oops, it must have slipped off the zerk fitting". I'm sure that there are still a lot of grease wads stuck on the ceiling.
  5. lobo loco
    lobo loco
    223
    Media:
    25
    1
    Apr 8, 2007
    Norcal
    Mo' grease guns
    Don't know if it's the best grease gun, but it's a Toyota one. Found it in one of my scrounging-searches new in the box. Haven't used it, as I have a pnuematic I use with a small compressor. Seems like I need three hands with the hand pump...especially on the U-joints and transfer linkage fittings. FWIW, a pic of the Yamada....
  6. crushr
    crushr
    882
    2
    Apr 12, 2006
    Concord, CA
  7. Cookiemonster
    Cookiemonster
    564
    1
    Jan 19, 2005
    CA Bay Area
    Try greasing a backhoe, or excavator.
    The one I've found that works best is a pistol grip with a flex hose.
  8. Cube Dweller
    Cube Dweller Moderator
    1,183
    11
    May 22, 2004
    22 Acacia Avenue
    Anyone found a good quality mini grease gun? And, does Mobil 1 come in the mini sized tubes?
  9. oldfj40
    oldfj40
    458
    Dec 17, 2006
    C.C.,B.C.
    Pretty good one.
    I found a tool kit in my '74 FJ55 when I got it.Not sure if it's the original kit for the truck but I assume it is.The tools appeared to be used with damage to the screw drivers.The wrench set and the tire iron looked great.
    Then I pulled this out of its side compartment.Still wrapped up and protected from the elements.I may be the first person to touch it since the factory tool kit guy in Japan.:D
  10. fj40charles
    fj40charles
    3,050
    210
    Dec 7, 2002
    Texas
    I have one of those too.
    The best grease gun for me is the Lincoln brand that you can operate with one hand. It does not have the long lever to pump. Like the one Cookiemonster posted up ^^^.
  11. n2666s
    n2666s SILVER Star
    2,622
    6
    Feb 21, 2006
    Have my old Lincoln that is so old it was made before cartriges, retired now but once in a while when there is a damn fitting that is very difficult to get to.....will bring her messy self out.........have acouple of newer cartrige Gguns that I use a lot, a mini and a regular sized one both Lincoln's with flexible spouts...........Alemites are nice also; the compressed air Gguns are nice but need the compressed air source and for me personally it is more conveniant to grab the manual..........anyone have experience with a compressed air powered grease gun injury?..........that is another thing that makes me shy away from them; just my chicken selfpreservation
    Lou
  12. rsbcruiser
    1,459
    Media:
    1
    5
    Aug 4, 2007
    Portland, Oregon
    Thanks guys. Looks to me like crusher is the winner for suggesting the Alemite pistol grip with flex hose. Maybe add a low clearance tip too it. 71FJ40s' description of the Alemites functionality? (inventing new words here) sold me on it. As far as the powered units, it seems to me they lean more to the profesional user. Although, If you own several Cruisers, its' relatively easy to be blessed with over a hundred zerks ! Making the powered units seem, at least rational for a home mechanic. Need FJ-55 greasable hinges crusher?
  13. Trollhole
    Trollhole THC Supporting Vendor Moderator
    19,840
    Media:
    79
    1,009
    Mar 6, 2005
    Mauldin, SC
    Bahhh Humbug. We all know the OEM Toyota is the best.:flipoff2:
    I don't use it but it sure makes a great conversation piece.
    How many people could you show a grease gun to and they say "Hey that is really cool"
  14. eleblanc
    eleblanc
    2,961
    Media:
    1
    8
    Jul 4, 2006
    Montreal
    I bought this one from alemite and it doesn't work s**t. almost impossible to purge and only push out grease on random occasion... It was cheap, i guess i should have bought a manul for the same price....
    http://www.alemite.com/catalog/details.aspx?identifier=guns_special&pid=F100&detailpage=true
  15. rsbcruiser
    1,459
    Media:
    1
    5
    Aug 4, 2007
    Portland, Oregon
    Wo, need to pay more attention to the categories. Looks like we got moved. Ya, sorry Trollhole, Memories of struggling with operational and reloading of the old style side pump pulls toward the pistol grip Alemite like an FJ-40 climbs trails. Looks as if voting favors the pistol grip and the Alemite. Gotta admit though. Nothing cooler than the stock OEM Toyota grease gun still in its' packaging. Sorta like having a pre 64 model 70 in the box. Ah function. The essence of Cruiser, Heaven forbid though, someone would make a decision relating to their Cruiser based on an emotional criteria. Such as, keeping a stocker FJ-55 just because you like it.
  16. cruiser88
    cruiser88
    11,876
    Media:
    3
    28
    Feb 21, 2006
    Medford Oregon
    That is what i have:). Clearence 16 bucks
  17. chet
    chet
    520
    Sep 20, 2004
    Vancouver Island, BC
    my dad has a trucking and excavating business and they just switched all the manual grease guns to the cordless Bosch I think these things kick ass! We tried air powered and had some interesting blow outs. the ones we had been using for years was the pistol grip ones. the ones with the long handle and fixed hose suck!
    Also use good quality grease nipples the cheap ones from the dollar store tend to lose the ball very quickly.
  18. lowenbrau
    lowenbrau SILVER Star
    3,606
    23
    Jan 22, 2003
    Calgary AB
    I agree with cookiemonster. You have to be able to squeeze with one hand while you're working your hose with the other.
    Wait a minute, is this chat?
  19. Cube Dweller
    1,183
    11
    May 22, 2004
    22 Acacia Avenue
    There was a guy on pirate selling MAC mini grease guns + 3 tubes of "green" grease for $15. He's not selling them anymore :frown:
