bearing question
Discussion in '40- & 55-Series Tech' started by tetradymite, Jun 10, 2003.
  1. tetradymite
    tetradymite
    18
    Feb 25, 2003
    Can anybody explain this?
    Prices for inner and outer bearings w/races:
    JTOutfitters - $25 each ($100 for entire axle)+shipping -SKF
    CoolCruisers TX - $39 each-sale ($78 for entire axle)+shipping - Timken or Koyo
    Autozone - $29 each side ($58 for entire axle)+gas for drive to store - Timken
    Is there a hidden quality issue for the bearings that I'm not aware of?
    'cause Autozone is known for their quality parts . . . :p
  2. 73lndcrsr
    73lndcrsr SILVER Star
    744
    4
    May 28, 2002
    I think all of those manufactures have a good rep. Check NAPA if you have one near you as well.
  3. s79bj40
    s79bj40
    359
    Feb 10, 2003
    Brisbane
    I just went out and brought mine yesterday from the shop down the road, it was a Timken set i think for Aud37.50 for one side. It came with the 2 bearings, races, hub oil seal, axle oil seal, rear hub gasket, 2 front hub gaskets, and that funny shaped metal ring thing that goes in the front hub.
    I shall put it in the 60series hub that is sitting in the back of the landy, then attach the hub to my bj using plenty of sticky-tape and bailing twine. Yes, that should do nicely.
    Sam
    '79bj40
    '76 serIII landrover
  4. Landpimp
    Landpimp GOLD Star
    14,679
    869
    Mar 14, 2003
    PNW
    try to find the CR(Chicago Rawhide) brand of bearings, in most cases they are Koyo inside the box. For instance rear semi float wheel bearings from the dealer are over $50, the CR bearings are under $20 and inside the box is a Koyo bag with a Koyo bearing :)
    I have found this to be the case with the fronts as well, I think they were even less $$
    I think CR is now owned by SKF.
    I use OEM seals from the dealer, they are not much.
    Timkin is good, IMOP Koyo is a bit better. For some reason I recall someone looked at a Koyo and a Timkin bearing(I forget for what aplication, might have been a 80 series front end) and the Koyo had one more ball bearing than the Timkin.
    John H
  5. s79bj40
    s79bj40
    359
    Feb 10, 2003
    Brisbane
    i got the impression from reading the timken box, that timken makes up its kits from all different suppliers. So depending on the application, its possible, the bearings for one car may be made by a different maker than the bearing for another.
    Sam
  6. dobro
    dobro
    23
    Apr 18, 2003
    TPI has a sale on everything right now, but the deal on autozone is great, I think.
    Dan.
