Backspacing
Discussion in '40- & 55-Series Tech' started by phlyfish, Jul 19, 2003.
  1. phlyfish
    phlyfish
    246
    Mar 1, 2002
    Boise ID
    I know that the boars say not to mess with the backspacing on the rim....But.....What is the issue with less backspaing. Can I run a 2" backspace and be fine?
  2. IDave
    IDave
    7,174
    Media:
    1
    13
    Jan 3, 2003
    McCall, ID
    Less is ok, I think. More's the issue.
  3. tclndcrz
    tclndcrz
    989
    Mar 30, 2003
    Charleston SC
    I think IDAVE is right. I dont see why not...
    Im going to be ordering new wheels soon with a little less backspacing than 3 1/2 which is the correct backspacing.
  4. del3030
    del3030
    30
    Feb 26, 2003
    This is confirmed correct. I just got a set of wheels off the PBB for my 78 FJ40. Like a dumbass, I didn't check the backspacing, just the bolt pattern. When I torque down the lug nuts, the steering arm gets caught in the inner part of the rim and the wheel won't turn.
    Sometimes, more is not better, just more.
  5. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
    Actually, by the book, 3 3/8" is the number, but thats not the point. Too much backspacing will rub on your steering arm and tie rod end, obvious problem. On the other hand, lesser backspace, further exaggerated by excess width, causes "scrub". In offroad this translates to that painfull experience of having the steering wheel ripped from your hands. It also causes higher stresses on wheel bearings, axles, steering knuckles, steering components, etc. Most of us opt for the wider wheel base, increased floatation and other benefits. We have nice "band-aids" like steering stabilizers and power steering to cover-up these ill side effects.
    It's best to stay close to the orig backspace.
  6. dylan
    dylan
    246
    Dec 23, 2002
    i got custom made 15x10 steels made wiht 3.5" backspacing and they f---ing rubbed the caliper in front. so now i have to grind the caliper and run a 1/4" spacer.be warned
  7. hammerhead
    hammerhead
    1,995
    Jul 5, 2003
    Central, Utah
