Backing Down Hills - S L O W L Y !!
Discussion in '80-Series Tech' started by CDN_Cruiser, Jul 28, 2003.
  1. CDN_Cruiser
    CDN_Cruiser
    1,047
    Mar 27, 2003
    Gang:
    Question for you. A few weeks ago I was out doing some trail riedes with my new found 'Rover' friends. Part of the trip included some very nice and steep sand dunes.
    I'm well aware that in both going down hills forward or backward, you want to use engine compression andgearing to slow the decent and completely avoid the brakes. I used to have a BJ60 that was fantastic for this - put it in 1st 4Low and let it walk down the hill - slow enough that I could have probably got out to pee without the truck passing me.
    I found that going forward the truck seemed to be fine and no temptation to hit the brakes. In reverse it seemed much faster. We were talking at lunch and I thought that going down backwad seemed faster b/c maybe the gearing was different. My Rover friends said that this would not be the case as I would be limited by my lowest gearing = should be the same speed.
    So, wha't the deal - how does this work?
    Cheers, Hugh
  2. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Somewhere in the foothills...
    Hugh,
    It is not your imagination.
    Automatic Transmission ratios:
    FZJ80 A343F 1-95 to 1-98
    1st: ... 2.804:1
    2nd: .. 1.531:1
    3rd: ... 1.000:1
    OD: .... 0.753:1
    R: ...... 2.393:1
    1st is lower (higher numerically) than reverse.
    The above numbers are for the technically superior A343F. The old bus transmission is 1st 2.950:1 and Reverse 2.678:1
    -B-
  3. Rogue
    Rogue
    968
    1
    Mar 27, 2003
    Jefferson
    [quote author=Beowulf link=board=2;threadid=3994;start=0#msg29286 date=1059453243]
    -B-
    [/quote]
    Isn't lower better Beo? I think I will have to tell everyone my logic on why the A442F is better. Shall I?
  4. Eduardo96FZJ80
    Eduardo96FZJ80
    634
    Apr 1, 2003
    Ohhh Nooo!! here we go again ::)
  5. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Rogue,
    >> Isn't lower better Beo? <<
    It depends on whether we're talking about grades (you) or golf scores (me.) :D
    -B-
  6. Rogue
    Rogue
    968
    1
    Mar 27, 2003
    Jefferson
    :eek:
    You know what I meant, and that the A442F is in fact the better gearbox. :D :D :D
  7. landtank
    landtank SILVER Star
    18,425
    600
    Mar 27, 2003
    Groveland MA
    Whatever helps you sleep at night there Rogue!
  8. Rogue
    Rogue
    968
    1
    Mar 27, 2003
    Jefferson
    I sleep great every night knowing that my transmission is still standard issue in other countries. :D
  9. Junk
    Junk
    6,185
    23
    Dec 13, 2002
    buggerville nj
    [quote author=Rogue link=board=2;threadid=3994;start=0#msg29417 date=1059525579]
    [/quote]
    So's your momma Rogue. :flipoff2: and we know how she digs your crappy bus trans. :flipoff2: Just hope she doesn't demand exact change :flipoff2:
    Of course the A343F is better, because that's what i have. :bigmasterflipofftolittlewhimsicaldude:
    That said, there is no reason to ever back down a hill! :eek: :D It's a frickin cruiser, go forward. :D :D :D :D :D
  10. cruiserdan
    cruiserdan SupportingVendor Emeritus Supporting Vendor Moderator
    20,603
    2,981
    Mar 27, 2003
    Surrounded by Cruisers from all over the world
    Um,
    Gentlemen,........The 442 is CLEARLY superior as it has one more solenoid than 343's do......... ::)
    In addition, It has a nifty and useful skid plate for the oil pan.................. :D (The latter being conspicously absent from a 343)
  11. CDN_Cruiser
    CDN_Cruiser
    1,047
    Mar 27, 2003
    Thanks for all the input. I would have loved to go forward, but I was just digging in deeper and none of the Rovers could get up the hill :p, so if I couldn't get out it would have been a problem :'(
    What about the point that going down backwards can't be any faster than the lowest gearing going forward - seemed like BS to me (and was verified by my seat-of-the-pants speedo), but then again I wasn't sure.
    Cheers, Hugh
  12. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    Hugh,
    >> seemed like BS to me <<
    That's why I gave you the gear ratios; to prove you have lower gearing in 1st forward than in reverse.
    -B-
  13. semlin
    semlin rocker
    5,209
    Media:
    1
    324
    Mar 27, 2003
    north of 49
    Wulf-man, quit giving Hugh the gears :D
  14. CDN_Cruiser
    CDN_Cruiser
    1,047
    Mar 27, 2003
    Ya, I'm now a 3 star! Sorry for the stupidity - Beo the gear ratios were perfect.
    What the LR folks implied is that in 4L going in reverse, you are limited by the lowest gearing (ie in this case the first gear) - anyways, enough - in my mind, even with a basic understanding of gearing, the reverse speed has nothing to do with the lowest (forward) gear (4H or 4L). Maybe in discos it's the same gearing (1st and R)?
    Cheers, Hugh
  15. CruisinGA
    CruisinGA
    6,163
    8
    Mar 27, 2003
    Georgia Tech
    Moral of the story:
    Don't listen to Rover people unless it concerns fine wine or faulty electronics. ::)
  16. Beowulf
    Beowulf
    12,534
    30
    Mar 27, 2003
    >> Don't listen to Rover people unless it concerns fine wine or faulty electronics. <<
    Bailey, you are wise beyond your years. :D
    -B-
