#%^ BACKFIRE
Discussion in '40- & 55-Series Tech' started by TOYOTADRUNK, May 19, 2003.
  1. TOYOTADRUNK
    TOYOTADRUNK
    81
    May 19, 2003
    MY 85 FJ60 W/HEADER,NO CAT CONVERTER,DE-SMOGED.
    RUNS GREAT,STARTS GREAT BUT BACKFIRES LIKE HELL WHEN I LET OFF THE GAS AT ALMOST ANY SPEED(WORSE WITH SPEED)CARB. HAS BEEN REBUILT BY JIM CHENOWITH 1000 MILES AGO,TRUCK DID NOT BACKFIRE BEFORE WORK WAS DONE.ANY IDEAS?
  2. 73lndcrsr
    73lndcrsr SILVER Star
    744
    4
    May 28, 2002
    How is the jetting? &nbsp:Do your plugs look okay? It sounds like it could either be too lean or you may have a timing issue.
    Hope this helps.
    BTW your plugs should be a light tan color.
  3. Pin_Head
    Pin_Head
    13,740
    1,309
    Feb 6, 2002
    OC, CA
    This is one of the unintended consequences of "de-smogging". Re-install the throttle positioner on the carb and hook it up to the VSV so that it works properly and the backfiring will go away.
  4. TOYOTADRUNK
    TOYOTADRUNK
    81
    May 19, 2003
    :D :D :D
    HEY,I FIGURED IT OUT MYSELF UNSCREWED MY FUEL CUTOFF
    AND THERE WAS A BIG BUGER IN THE END OF IT, SPRAYED SOME CARB CLEANER IN IT AND THE HOLE WEAR IT THREADS AND WALA NO MORE #%^ BACKFIRE.I LOVE MY CRUISER!!!! :G :G :beer:
