axle upgrade
Discussion in '40- & 55-Series Tech' started by rusty40, Aug 8, 2003.
  1. rusty40
    rusty40
    91
    Mar 6, 2002
    I am wondering can I use the birfs and knuckles and hubs from a fj60 on my 72 landcruiser axle housing without changing the inner axles
    what i really want to know is are the inner shafts fine splined at the birfields end?
    thanx
  2. cruiserman
    cruiserman
    1,861
    Mar 27, 2003
    Yes, you can. You will need to grind a little on the lower axle housing for the larger fj60 birfields. IIRC the knuckle arm tie rod end taper is different, so you'll need to put in taper inserts or cut down a 60 rod. Check the tech links for details.
  3. rusty40
    rusty40
    91
    Mar 6, 2002
    luckily I have the whole housing and all the tie rods :D
    on the short side i can swap the whole fj60 birfield and inner axle cuz its the same length as an fj40
    do the fj80 tie rod ends have the same taper as the fj60??
  4. cruiserman
    cruiserman
    1,861
    Mar 27, 2003
    I think they are larger.
  5. rusty40
    rusty40
    91
    Mar 6, 2002
    does anyone know what size the spindle nuts are??
    they look pretty big :eek:
    And if I remove the Disc brake dust shield will that mess up the spacing between the spindle and the knuckle ???
    mine are so rusty they arent worth putting on :eek:
