AVAILABLE 7X SERIES PARTS--USA MARKET (2 Viewers)
You need the bearing retainer, input shaft, bell housing and clutch parts and transmission mount.
No, you cannot in the US market.
Can one purchase the H55f already set up for the 1HZ?
it exist certainly ..
Beno which are the necessary parts for the input conversion .?
1HZ radiator into a 7x series. Get them before Toyota realizes these radiators should not be for sale in this market.
:rolleyes:.
EPIC THREAD!!! will that rad fit a B series? Can I get it in Canada? How much?
Thanks bud for all your leg work, I love just the pictures, hahaha
No.
3B inlet and outlet are on the LH side.
1HZ/HD set up is inlet on top LH side outlet on bottom RH side.
That really sucks... The price would probably scare me off anyway. thanks for the info, much appreciated!
Brake Master cylinder (for RHD BJ70 iterations only):
And gasket to brake booster:
And nuts to install on studs:
Shorty fuel filter. This would work for all North American 3B engines (BJ42/60/70). Also applicable to European market 4x series with B/3B engines, 7X series with 3B and 60 series with 3B. Japanese market 4x with a 2B and BJ60's with the 3B.
Fuel filter 13BT, H, 23303-54072
24v oil pressure sender for with gauge, 83520-60020
Windshield for fold-down frame, 56111-60230
Weatherstrip for above without moulding, 56121-90K01
Weatherstrip for with moulding (non-import, requires VIN and import papers) 56121-90K03
RH wiper blade, RHD, 85220-32120
LH wiper blade, RHD, 85220-22600
Rear wiper blade, 85220-22300
Locking fuel cap, 69058-60141
"Diesel" fuel cap, non-lock, 77310-35061
24v instrument panel bulb, 99134-12030 3watt
24v marker bulb, 90981-12012, 5watt
Washer jar, later style tall, 85315-60210
Fender apron seal (curtain between inner fender and frame) 53737-60040. Fits both sides needs to be trimmed to clear exhaust pipe.
13BT A/C compressor, less clutch, 88320-01011-84
13BT voltage regulator, 27700-57080
Parking brake lever, black, may need to swap switch, 46210-60230-C0
Boot for above, black, 46243-60060-C0
When I looked up the replacement part numbers for my RHD 70' they gave the following:
RH wiper blade, RHD, 85220-12570
LH wiper blade, RHD, 85220-22470
Have these part numbers been replaced with the numbers above?
Hi Beno,
I need for my HZJ 73 this frame in order to fit 2 DIN Radio CD. I do not know the part number but may be you can help me ?
As well I need a new vacuum pump for the same car P/N 29300-17010 .
Thank you !
Those two part numbers are not available in the US market.
@cruiserdan has found part numbers that work with our trucks and parts that are readily available in the North American market through Toyota.
Hi Beno,
Thank you !
55413-90K00 is the bezel part number for the double DIN.
The pump itself is probably discontinued, but you can get all of the parts internal to the pump to rebuild it.
I'm interested in the windshield wiper blade part numbers if anyone has them available (RHD - HJ75).
@beno, are 2H oil filters available? I was able to find one from my local NAPA that works, but I would prefer an OE filter for future changes. The Napa # is 1627 if that helps. It's a large spin on filter with an o-ring.
I know this is not bought at a local toyota dealer but there's nothing like punching keys and having stuff show up at the door.
I've had great success finding part numbers here MegaZip: OEM Motorcycle Parts, ATV Parts, Marine Parts, Automobile Parts
And ordering parts here Amayama Trading
Quotes take a couple business days after submitting. Parts are sourced out of Japan or UAE. Then shipping is pretty quick. And the parts are usually cheaper then those ordered in North America.
While these parts are not available in the US market, it is worthwhile making a note on these two part numbers:
12361-58061: Engine mounts for a 13B-T
12361-58031: Engine mounts for a 3B
(JDM both)
As you can see, the parts are identical in every manner shape and form. This is good cross-referencing information.
Best regards.
-onur
Aftermarket manufactures state a rubber compound difference between the two, guessing due to balancing/torque differences?
