- Thread starter
- #41
This is a universal auxiliary relay panel, so it will work in any vehicle including your JK. The relay coils are resistor dampened to minimize switch noise which is important for newer vehicles that are sensitive to electrical noise. This matters if you wish to use ignition ACC 12 volts as a source to switch on the relays. If you are not planning on using ignition ACC voltage to switch on the relays, then you can use the constant 12 volt wire that I supplied with the relay panel, and all the auxiliary wiring will be completely isolated from the rest of the vehicle.
